I am interested in how these larger tyres affect your torque? I put on some 265x70x17 LT ATR Pirelli shortly after I bought my Prado (~60k ago) and have noticed towing a trailer that 1st and especially 2nd gear (D4D 6 speed) seem a bit tall and lacking some oomph! I hadnt thought until reading this thread that the larger tyres could be causing the problem? According to my calculations there is about ~1" rolling diameter difference in the std 265x65x17 Prado tyres and mine.…could that really be making the difference? Has anybody else with the 6speed D4D noticed this? I realise there may not that be that many vehicles out there with this manual diesel configuration? I also imagine its probably not an issue with the auto or petrol engines is it? I now need some new tyres and suspension lift/upgrade (it's amazing how much the standard suspension has sagged) and trying to decide what my best option is? Maybe I should chip it and put a massive exhaust on it.....haha, my son would love that! Lol
what sized tyres fit standard rims no lift
02/07 Prado GXL D4D 6 sp manual bought Oct 2009 with 43k on the clock. ARB bullbar and Redarc dual battery system, safari snorkel, 2" OME lift, front ARB air locker, Cooper Discover S/T Maxx LT265/70R17s, 17" black CSA steelies, GME TX3520 80 ch UHF, Dept of Interior rear roller drawers, full length Rhino-Rack and Sunseeker side awning.
G'day BBB, I've got the same model prado as you (08 though) i'm running 265/65R17 BFG all terrain's and i reckon it's fairly punchy in the lower gears so perhaps your tyres are the problem. It's stock except for a snorkel and it has now done 175k injectors are original still goes well. Put it this way, i had a D4D manual hilux before the prado and the prado eats it for breakfast!
Cheers.2016 1GD GXL 6 speed auto, ARB colour coded summit bar, LED driving lights, duel batteries, BF Goodrich tyres, window tint.
BBB, I'm with azzss. Standard size 265/65/r17s BFG all terrains, 6sp manual and now running 3" Sterling exhaust. Before the exhaust it had plenty off get up and go, but now takes off like a rocket. Haven't put a performance chip in, but the bigger pipe on its own makes a big difference.2009 White KDJ120R Manual fitted out for family camping and touring - See my Rig Build at [url]http://www.pradopoint.com/showthread.php?27887-Smithy-s-Rig-Build[/url]
Originally posted by Smithy - 120 D4D View PostBBB, I'm with azzss. Standard size 265/65/r17s BFG all terrains, 6sp manual and now running 3" Sterling exhaust. Before the exhaust it had plenty off get up and go, but now takes off like a rocket. Haven't put a performance chip in, but the bigger pipe on its own makes a big difference.02/07 Prado GXL D4D 6 sp manual bought Oct 2009 with 43k on the clock. ARB bullbar and Redarc dual battery system, safari snorkel, 2" OME lift, front ARB air locker, Cooper Discover S/T Maxx LT265/70R17s, 17" black CSA steelies, GME TX3520 80 ch UHF, Dept of Interior rear roller drawers, full length Rhino-Rack and Sunseeker side awning.
I regularly swap between the 265/65R17 AT20 and 265/65R17 MT/R. I have the V6. There is definitely a difference with the performance as I can feel more punch when I go back to the AT20s.
The difference in diameter and construction of the tyre contributes to the 'punch'. Being a bigger tyre, you also have the weight further out from the hub which requires more energy to spin.
You would need to change the diff ratios to get the 'punch' back.
Originally posted by BBB View PostHaven't yet researched 3" exhausts and I'm sure there is heaps of info elsewhere on this forum regarding that but can I quickly ask you Smithy, what that cost you to fit and did it also affect your fuel consumption? Cheers,
Hope this helps.2009 White KDJ120R Manual fitted out for family camping and touring - See my Rig Build at [url]http://www.pradopoint.com/showthread.php?27887-Smithy-s-Rig-Build[/url]
Originally posted by azzss View PostHey Smithy,
Is there much exhaust noise in the cab? ie drone?
Cheers.
Personally I think the exhaust sounds tough, especially on sand dunes with the revs up!2009 White KDJ120R Manual fitted out for family camping and touring - See my Rig Build at [url]http://www.pradopoint.com/showthread.php?27887-Smithy-s-Rig-Build[/url]
Even 265/70 /17 is also illegal as you are only allowed 15 mm over standard and thas with a 2 inch lift
Originally posted by Anth120playdo View PostHi,
I tried.....285/70 hitting big time. Simply they are too big. You could change the offset but this will just change where they rub. I know there are some ppl with 33's.
In the end I didn't even bother trying 275..... Because its only gonna give 6mm more clearance than a 265/70-17 so i went with what I knew fitted!
Bigger tyres = less power
With 265/70 speedo is accurate, with anything bigger vehicle is unroadworthy due to speedo under reading which is not allowed.
Simple decision really.
Hope that helps.
