Rear Toe-In Readings
  • Rear Toe-In Readings
    Dear All ,
    Fazza Mate
    A quick question ; Last Week I did my tyre rotation cycle and my tyres are great so far , however I did a wheel alignment as a safety measure to correct any missing front toe-in that was brought down from 0.9 to 0.2 which is close to 0 so I think it's ok
    However the rear wheel toe-in reads 2.2 and 1.8 L to R
    I believe previously we discussed that this is not a big deal since the rear wheels are not doing any turning , and one can't fix rear toe-in any ways but would you say that 2.2 is OK for rear toe-in and if it's not ok, then how to fix it ?
    Cheers Mates :P
    White VX LC120:2006
    Re: Rear Toe-In Readings
    Originally posted by mansour
    Dear All ,
    Fazza Mate
    Cheers Mates :P
    Mansour,
    No problems with the front toe setting,
    The rear as you state is none adjustable as such, unless you what to go to the trouble of bending the axle housing.(Don't go there) cost would be prohibitive.
    It would be cheaper just to replace tyres.
    2.2 is a little excessive but I cannot see it causing any problems.
    I also makes you wonder at the accuracy of their readings :idea:
    Have you notice any excessive wear on your rear tyres :?:
    All will be well,
    Fazza
    07 Silver Ash, GXL, D4D, Auto. Lifestyle rear cargo rack. 2500 kg Tow bar with Tekonsha elec brake controller, Rear dust deflector, Mio Sat nav, (Still trying to fault the Dunlop AT20's)
      Rear Toe
      Thanks Fazza Mate
      No ihadn't had any wearing yet , I will keep an eye and check
      But to be honest the scorpions are very good in this department
      I had to travel in between cities in the past 2 weeks and I did 5K which I usually dop in 3 months and all in speeds betweeb 140~160KM/Hr (The upper speed limit in Highways here) and the tyres are barely chipped the sides
      We had downpores like what I used to experience in Sydney - Am serious here in the desert- (speaking of global warming) and the wet performance was OK OK OK
      Any ways you are right about the accuracy of readings , I will keep an eye on the tyres and let you know
      Thanks A million Fazza Mate
      White VX LC120:2006
