Ok how much bad luck is this. This Cooper ATR is just 1 day old. Only an hour or so into a drive ! This happened on a normal dirt / gravel graded road. Plenty of non 4wd vehicles use this road daily, i.e. The average sedan etc. I could not find the rock that caused it and I did have an extensive look. But it was bound to be a rock just sticking up from the surface a little bit.
Oh well - Guess this is either bad luck - or poor tire selection. I very nearly put BFG AT's on it... Perhaps I should have ! They look a bit more "Solid" then the Coopers. Was running 34 PSI at the time. - Perhaps this is too much ?
Anyway - not very impressed with either my luck - nor the tyre's
![](http://www.postimage.org/aV1QbH7S.jpg)
![](http://www.postimage.org/PqqitUA.jpg)
