Tyre Size Qn
  • Tyre Size Qn
    Hi all
    I am after any input / comments on the following. Have a prado with D694 265/65R17 (tyre 1) and we recently got a trailer that has 265/70R16 (tyre 2).
    Is it good engough in a flat tyre situation to use the Prado spare on the trailer and visa versa??
    Here was some info on the differences between the 2 sizes - seems very little -
    Results for your selected Wheel/Tyre 1
    Rolling Radius 388.15mm
    Circumference 2438.82mm
    Diameter 776.3mm
    Wheel Cover Size Size 007
    Results for your selected Wheel/Tyre 2
    Rolling Radius 388.7mm
    Circumference 2442.27mm
    Diameter 777.4mm
    Differences between Wheel/Tyre 1 & 2
    Rolling Radius 0.55mm
    Circumference 3.45mm
    Diameter 1.1mm
    When your speedo reads 100km/hr you're actually at 100.14 km/hr
    I am no tyre expert so looking for help!
    TIA
    Borgy
    Prado VX Diesel 2007 Silver
    Lots of add-ons...
    [url=http://autos.groups.yahoo.com/group/aussieswag/join][img]http://autos.groups.yahoo.com/group/aussieswag/[/img][/url]
    [i]Click to join aussieswag[/i]
    1.1 mm wouldnt be an issue, Though I would suggest measuring them yourself as they may vary up to 20mm or more with wear.
    Putting a different diameter on one side would possibly cause some wind up in the driveline.
      Borgy, i also beleive that the 16 inch wheel will only go on the back axle of the car without mods to the brake calipers on the front.
      [b]Rob[/b]
        Borgy,
        I would be more concerned about wheel offset & clearance with the wheel against brake calipers etc on the Prado.
        There may have been earlier articles on this situation before :?: :?:
        Fazza
        Hutch you beat me by two minutes :wink:
        07 Silver Ash, GXL, D4D, Auto. Lifestyle rear cargo rack. 2500 kg Tow bar with Tekonsha elec brake controller, Rear dust deflector, Mio Sat nav, (Still trying to fault the Dunlop AT20's)
          Recently due to an insurance loop hole I had the opportunity to get a slightly damaged rim repaired and keep it for the camper. Anyway, huge offset difference. The wheel actually went in and hit the chassis of the trailer so I gave up. Just check it out before you assume it will fit.
          Matt
            Your measurements wont affect your rolling diameter equation, so no driveline issues
            But I would be confident it would affect the "driveability" of the car
            I would reserve the equation for Prado wheel on trailer only, or trailer wheel to car in unavoidable emergencies only, and only ever on the back (1) because it wont fit on front and 2) because it wold have least effect on steering
            Next problem is offset, the Prado wheel is (off memeory) positive 30 (?) and therefore a little unusual
            Different offsets, whilst they may fit without rubbibg then could change your track and that would not be a good vehicle to drive, at a guess if you had an accident with the 16 on the car insurance co. would wave bye bye, even if it was only an emergency fitment
            Here is a good site for doing comparisons on all things wheel and tyre
            http://www.rims-n-tires.com/rt_specs.jsp
            I'd be looking for another plan Borgy ops:
              Hi all
              And thanks to all your replies and info provided
              I pretty much thought that about moving the 16's from the camper to the Prado - (that visa-versa was a last minute add to my original post)
              My thinking / question really was mainly directed at taking the spare Prado tyre and putting it on the camper incase of a flat! [yes don't have a spare on the custom camper [as yet ops: ])!
              Thanks again
              Borgy
              Lots of add-ons...
