Hi all
I am after any input / comments on the following. Have a prado with D694 265/65R17 (tyre 1) and we recently got a trailer that has 265/70R16 (tyre 2).
Is it good engough in a flat tyre situation to use the Prado spare on the trailer and visa versa??
Here was some info on the differences between the 2 sizes - seems very little -
Results for your selected Wheel/Tyre 1
Rolling Radius 388.15mm
Circumference 2438.82mm
Diameter 776.3mm
Wheel Cover Size Size 007
Results for your selected Wheel/Tyre 2
Rolling Radius 388.7mm
Circumference 2442.27mm
Diameter 777.4mm
Differences between Wheel/Tyre 1 & 2
Rolling Radius 0.55mm
Circumference 3.45mm
Diameter 1.1mm
When your speedo reads 100km/hr you're actually at 100.14 km/hr
I am no tyre expert so looking for help!
TIA
Borgy
Diameter 776.3mm
Diameter 777.4mm
Diameter 1.1mm
TIA
Borgy
