Got 4 x 265/65/17's at Bob Jane's in Essendon, Vic. $336 each. Stock was available next day.
BFG price
D4D 2009, Auto, White, ARB Deluxe Bullbar, IPF 900XP driving lights, Red Arc & 2nd Battery, ARB compressor, Maxtrax, BFG AT's, Fourby Fitout drawer system, ARB 47ltr Fridge, GME UHF, ARB reversing camera mirror, SCA Sheepskin covers, 12/240v Inverter, ARB awning hanging from wire basket, 9000lb winch.
G'day 150gxl.
I've been having trouble finding anyone that can provide 265/70/17 in Brisbane without stating a 2-3mth wait. But I dropped into Jax Quickfit at Slacks Creek this afternoon and old mate there (James Sullivan) made a couple of phone calls and found that a shipment was coming in this week and they should be available in Brisbane in the next week to ten days. We put five(5) on backorder immediately and apparently I've secured them.
I've been quoted me $355 each, with seems a bit more expensive then our southern state counterparts, but I'm just happy to be able to get them. If you need some, you might be able to make a phone call and order some without the 2-3mth wait.
Best of luck.2006 GXL TDI, 2" EFS Springs, Safari Snorkel, Pirahna Dual Battery System, Custom storage drawer, 60lt Waeco, BFG All Terrains, Custom made spare wheel mounted adjustable rear spot light.
I went up to my local Bob Jane this morning looking at tyres and they said they would not fit anything in a 265/70/17 as it was legally too big which i thought was fair enough.
They did however suggest going for a 275/65/17, has anyone had any experience with this size? I asked if they would be too wide and rub on suspension components etc but he said it should be fine... he didn't sound too confident though.Justin
2005 120 Series 3.0 TD Auto, OME suspension, Sovereign bullbar, IPF 900XS driving lights, Projecta dual battery system, ARB roof rack, Bridgestone D694 tyres, GME UHF, Custom rear drawer with ARB fridge slide and Waeco 60lt fridge.
I have the 275/65 17s BFG A/Ts. No problems with the fit except you need to have spacers on the spare carrier otherwise the tyre will push against the rear door/wiper. AMTS is the man to contact http://www.pradopoint.com/showthread...-12mm-amp-20mm. My Prado has a 2" lift so I cannot comment if the vehicle is standard height.
If you search the archives there are quite a few posts about 275/65 tyres. You might have to edit your profile - General Settings - Thread Display Options - Default Thread Age Cutoff -> Show all threads.
A few shots of the tyres on my Prado http://www.pradopoint.com/showthread...r-my-120/page2My 150 build - http://www.pradopoint.com/showthread.php?27423-A-Random-approach-to-a-Bluestorm-150-GXL-D4D-automatic
Tests with Decataur and Falcon mobile radar, combined with GPS show that when using the 265/70 the speedo reads 100% accurate right through the range - Mr Toyota has your speedo reading a little faster than you are actually travelling when using the stock 65 series tyres. The wiper will function ok but you will need a spacer to hold the tyre/rim on the rear carrier properly. There a couple of options to fixing this including purchasing spacers from the "for sale" section on this forum. I simply welded some 20mm flat bar on the tyre carrier and welded on some longer studs.Dave
Yeomanda, check post #34 above for the link to amts spare wheel spacers. As far as your speedo is concerned, it depends on how old your Prado is. Mine is a 2004 model and the speedo reads exactly correct with standard 265/65/17. Newer models like Bushbasher's 2009 model read accurately with 265/70/17."Sure it’s quiet, for a diesel, but that’s like being well-behaved… for a murderer."- Jeremy Clarkson
Had a price today for 265/70/17 BFG AT for $335each fitted and balanced. Northside Brisbane MitcheltonSilver 2011 Toyota Prado GXL D4D Auto, Colour Coded ARB Deluxe Winch Bar, VRS9500 Winch, ARB Underbody Protection, Outback Ideas Recovery Points, Redarc Electic Brakes, Hayman Reese Towbar, Toyota Roof Bars, 265/70/17 Mickey Thompson 4 Rib, Kaymar On Door Rear Tyre Spacer, CAT Electronic Rust Protection.
Originally posted by pjorek View Posti was quoted $422 per tyre yesterday and almost fell off my chair, will ring around as this is pure roberyJustin
Hi CraigM yes they could get stock for next day fitment.Silver 2011 Toyota Prado GXL D4D Auto, Colour Coded ARB Deluxe Winch Bar, VRS9500 Winch, ARB Underbody Protection, Outback Ideas Recovery Points, Redarc Electic Brakes, Hayman Reese Towbar, Toyota Roof Bars, 265/70/17 Mickey Thompson 4 Rib, Kaymar On Door Rear Tyre Spacer, CAT Electronic Rust Protection.
Just ordered 265/70/17 for 370 each. I was told that reatil price is $440 ! I thought these would have been cheaper seeming there are lots more cars on the road that take this size now. KM2's were out of stock with 200sets on back order. Cooper STT's were still over 400. Hope this helps anyone looking.
phil06 120 GXL 1KZ-TE man, modified exhaust, K&N, OME 2",spacers, Sovereign BB, Safari Snorkel, Hella 4000, 33" muddies, ARB 60L fridge / slide ,custom rear drawer, cargo barrier and table, Ironman 9500lb Winch, TJM underbody guards, DIY Radiator bash plate, Outback Ideas recovery points, AJ's sliders, CKMA12, lockers, ext rear breather, UHF, dual batt, SBi12, ARB alloy roof cage, ARB side awning...
