The short answer is no. 120 Series must use 17" rims as 16" rims do not clear the brake calipers. Have heard of people grinding a bit off the brake caliper but that seems dodgy to me in regards to heat dissapation.
Regards,
Big Fella
2007 Prado GXL D-4D Auto. Black. Cooper ATR's, ARB Bull Bar, Safari Snorkel, ARB Dual Battery, Sandgrabba Mats, Black Duck Seat Covers, Plastic Bits on the front, Mesh Grill Guard, Tinted Front Windows, Towbar, Reverse Sensors, Lightforce Blitz 240's, ORS Drawer System. ScanguageII, Stebel Truck Horn, Icom 440 UHF Radio and BIlstein/Ridepro Premium Lift Kit.
If you can't fix it with a hammer...... you have an electrical problem.
I have had 7 x 16" 90 series steel rims on my 120 for three years now with no problems .Done over 70,000 ks with them on . I have 265/75/16 tyres on the car. Never had a problem with overheating?? . Yes I took a bit of metal of the callipers, bit like taking the corners off a box. I know you are not to modify the brakes but I take this as meaning bigger / smaller discs, or bigger / smaller callipers with more or less pistons ect , I have no way altered the way the brakes were meant to work from factory, smoothing the rough castings off and painting them is hardly altering them . If you put Bendix 4X4 pads on you have technically altered the brakes from factory spec or fit grooved or drilled rotors /discs you have also altered the brakes,
