Last November we replaced the Cooper 265/65 ATR's with new 265/70 ST's.
Did a couple of short trips prior to Christmas, playing in the bush and was really impressed with their performance. (This is my 4th set of Coopers on 3 different 4WD's)
Around town they are slightly noisier, but nothing over the top (actually, quite a pleasant humm) and there was no noticable difference in performance.
We have the old 3ltr diesel, but had a DP Chip installed not long after we bought it as we do a bit of towing and there was a noticable lack of pulling power on big hills when fully loaded. The DP Chip fixed the problem nicely.
We have just come back from 3 weeks up the coast towing our Jayco Eagle Outback and the performance drop was significant. Hills that I previously glided over at 80kph + I was struggling to stay above 60kph. It was as if the DP Chip had been turned off.
I have had the Prado in for its 95k service since returning and all was in order (air filter was changed, but still acceptable). I have checked the operation of the DP Chip and its also good. The only variable I can see is the larger diameter tyres. I was told at the time there may be marginal impact on performance with the 70's, but in this case its enough to take the edge right off.
Just food for thought if you are considering going up a size, particularly if you tow. (Obviously not as relevant to the V6, or D4D owners either)
PS: Can't fault the Cooper ST's though, they are a huge improvement off road over the ATR's.
