Ok, I've spent quite a bit of time reading the threads here on PP regarding new rubber. I've finally worn down the GrandCraps and have been looking around for replacements. I will either be going with Dueler 694 LT, or BFG A/Ts.
The issue of tyre sizing is confusing. From my understanding, you can't increase tire diameter more than 15mm in SA (and I'm pretty sure elsewhere).
So, first question: 1) Am I right in concluding that BFG 265/70/17 increases overall tire diameter by by approximately 26mm, which subsequently means it doesn't comply with regs and is ultimately illegal?
2) Dueler 694LTs in 275/65/17 are legal because they increase overall diameter by about 13mm, therefore coming in under the 15mm allowance?
The point with the second question here is that i've been reading up on mods and apparently, I can only increase ride height by 50mm. This includes both increases due to tyre change and suspension. So, even though the 694s in 275/65 are legal, as soon as I raise my suspension (in about 2 months), I will have exceeded the 50mm overall limit right?
So, can someone confirm that my reasoning here is correct? Is it the case that if I want a lift then I am going to have to stick with 265/65? If I were to get a CPE certificate for the larger tyres, do you know if I would then be able to legally lift by another 50mm with suspension?
Excuse my rambling here guys, but I am finally starting to mod the prado and the more I read the more confused I get. Most questions I have I've found answers for, but just thought i'd throw these questions out there for clarification because i think my conclusions are correct???
Thanks in advance -
Ian.
Thanks in advance -
Ian.
