Prado 150 grill removal
  • Prado 150 grill removal
    Hi
    Trying to remove the grill from my Prado GXL to fit screens behidd it to the stop the larger insects. I have removed all the lugs from the top cover plus one each side the connect to the piece next to the lights.
    I am having trouble removing the 4 lugs between the grill and the bumper bar below the grill. As well as that, I can't work out how to separate the grill from the piece of the bumber next to the lights. I can see it attached with tiny lugs under a rubber tube but think it might also be attached lower down between the bumper bar plastic near and the lights and the grill itself.
    Is anyone able to post a step by step? I would appreciate assistance as I have spent ages trying to work out why it won't pop out.
    peterpanner
    Prado GXL 2012 Charcoal - Drifta Drawers, Cargo Barrier, Sidewinder Dual Battery kit, Ironman Bar, Narva lights, Safari Snorkel, Airbags, TX3350 kit, Waeco CFX65DZ - often seen with Thule 2.2M narrow roof pod and towing 2014 Kimberley Kamper. Could be anywhere!
    http://www.pradopoint.com/showthread...tor-Bug-Screen
      Thanks but this doesn't solve the problems of the 150 grill being difficult to separate from the light surround
        So from memory,
        Remove top cover,
        Remove two bracing straps from grill at radiator support with Phillips head,
        Remove inside edges of weather seal on outside top of grill by gently stretching of their clips,
        Remove one plastic clip per side on inside (under weather strip),
        Use a small flat screwdriver to gently release the three or four clips from grill on each side,
        Pull grill away from bumper at bottom & hey presto you're done
        Pete t pops
          Thanks Pete,
          I will give it another go at the weekend
          Peter panner
            Originally posted by peterpanner View Post
            Thanks Pete,
            Peter panner
            Have a look at my HID install guide for the 150, it shows how to remove the grill with lots of pretty pictures
            http://www.pradopoint.com/showthread...ights-(GX-GXL)
              I have never done it but noticed this video shows it being done.
              http://www.youtube.com/watch?v=UxAfHWglNmU
              Watch from about 1:30
                Thanks to all the contributors
