Just wondering if anyone has looked very closely at the wiring on the 150's and worked out where to safely get a switched power source from? Im installing my GME UHF and whilst I can run it direct to the battery, id rather run it via a switched circuit so I dont kill the battery everytime I forget to turn it off.
Finding Accessories power for UHF - Anyone?
My Rig: 150 GXL D4D, Tough Dog adjustable suspension with 60mm lift, Polyair bags, ARB Winch Bar, Warn Winch with Dynamica Rope, Outback Ideas recovery points, GME UHF, HID Low/High Beam, Lightforce Genesis HID Spots, Dual Battery Setup with rear power outlets, ARB air compressor in engine bay, ~30L Watertank mounted behind fueltank.Tags: None
Re: Finding Accessories power for UHF - Anyone?
Originally posted by DavrosDo you have a multimetre?
Just look for a live wire only when accessories is switched on and go from there.My Rig: 150 GXL D4D, Tough Dog adjustable suspension with 60mm lift, Polyair bags, ARB Winch Bar, Warn Winch with Dynamica Rope, Outback Ideas recovery points, GME UHF, HID Low/High Beam, Lightforce Genesis HID Spots, Dual Battery Setup with rear power outlets, ARB air compressor in engine bay, ~30L Watertank mounted behind fueltank.
Sorry I shouldnt have been so dumb in my questioning. I was more interested to see how others have done this due to reports of the electrics being extremely touchy. I have no problems playing with the Multimeter
I don't have a 150, but have installed plenty of accessories in many vehicles over the past decade or three.
Most later model vehicles have dedicated piggy backs on the looms for fitting after market accessories.
If it were me, I would have a good look around for something like this to power your UHF. UHF radios don't draw much power, so you shouldn't have too much trouble finding a good source that is totally isolated from the computer.... which is where you may get flakyness. Not sure if flakyness is a word.2008 Diesel Prado with extra stuff added. I drive it on the road and other places too.
A humble word of advice. Still wire your UHF direct to the battery with 4mm wire or better, but have this switched via a relay that is powered via your accessory switched source. ( when you find one).
This achieves a few things
1. lowers risk of overloading your accessory wiring. ( driving a relay is much less load than a UHF on transmit ).
2. ensure a good supply to your UHF.
3. still enables your UHF to switch off when you remove the key ( although it would be simple to rig a switch that bypassed the relay so you could have it on all the time - handy in some situations )Cheers, Wayne
Originally posted by DavrosSorry I shouldnt have been so dumb in my questioning. I was more interested to see how others have done this due to reports of the electrics being extremely touchy. I have no problems playing with the Multimeter
Originally posted by DavrosI don't have a 150, but have installed plenty of accessories in many vehicles over the past decade or three.
Originally posted by ozwapet2A humble word of advice. Still wire your UHF direct to the battery with 4mm wire or better, but have this switched via a relay that is powered via your accessory switched source. ( when you find one).
3. still enables your UHF to switch off when you remove the key ( although it would be simple to rig a switch that bypassed the relay so you could have it on all the time - handy in some situations )My Rig: 150 GXL D4D, Tough Dog adjustable suspension with 60mm lift, Polyair bags, ARB Winch Bar, Warn Winch with Dynamica Rope, Outback Ideas recovery points, GME UHF, HID Low/High Beam, Lightforce Genesis HID Spots, Dual Battery Setup with rear power outlets, ARB air compressor in engine bay, ~30L Watertank mounted behind fueltank.
Good point raised above however things have changed over the years as far as direct wiring to battery for power. Years ago, most UHF tranmitters would draw a reasonable current. I used to wire them up with a direct fused supply from the battery. These days, the better quality units draw next to no current on TX. Example.... the modern day GME 3200 or 3400 only pulls about 1.5 amps. There is another issue that sometimes comes up though, which is negated by wiring directly to the battery. This is where dodgy previous installs have affected the acc circuit. Noisy curcuits from dodgy installs can have a bad effect on your equipment's performance. This shouldn't be the case for you because your car is shiney.2008 Diesel Prado with extra stuff added. I drive it on the road and other places too.
Hi There
I have put my UHF in and wanted to make sure I got a good power source that would work with the ignition. Answer was to run to the ciggy plug. Rather that taking half the dash apart to get behind the plug in the console I jumped into the one on the back of the console at the rear seats. It is easy to pull the trim off and get to the wire. To run the wire it is easily pushed back up under the edge of the console trim alongside the carpet to get it back behind the dash where I located my UHF. Ciggy power is totally seperate from everthing the computers use and works with your ignition.
Cheers[color=#4000FF]2010 GXL, ARB BAR, GOODYEAR MTR'S ON STEEL RIMS, CUSTOM REAR DRAWERS, DUAL BATTERIES, CARGO BARRIER, GME UHF, RHINO ROOF RACK, ROCK SLIDERS, AIRTEC SNORKEL, DUAL DROP FRIDGE SLIDES[/color]
Cheers2009 Prado Kakadu silver Auto with towbar. Redarc dual battery system, Redarc remote brake controller, Airtec snorkel, GME remote 3340 VHF CB radio, 12v heavy duty plug in cargo area, anderson plug to rear, ARB air compressor, Jayco swan outback 2007.
Originally posted by DavrosGood point raised above however things have changed over the years as far as direct wiring to battery for power. Years ago, most UHF tranmitters would draw a reasonable current. I used to wire them up with a direct fused supply from the battery. These days, the better quality units draw next to no current on TX. Example.... the modern day GME 3200 or 3400 only pulls about 1.5 amps. There is another issue that sometimes comes up though, which is negated by wiring directly to the battery. This is where dodgy previous installs have affected the acc circuit. Noisy curcuits from dodgy installs can have a bad effect on your equipment's performance. This shouldn't be the case for you because your car is shiney.
I guess with these new units you could get away with tapping into the cig lighter feed wire. Looking at the difference in thickness between the wire that comes attached to the radio power plug, and the vehicle wire you are tapping in to, should tell you a lot.Cheers, Wayne
Originally posted by ozwapet2Originally posted by DavrosPerosnally I'd still be happier wiring direct to the battery but I guess you could get away with tapping into the cig lighter feed wire.
For this reason I ended up going straight to the battery, not via a ignition circuit.My Rig: 150 GXL D4D, Tough Dog adjustable suspension with 60mm lift, Polyair bags, ARB Winch Bar, Warn Winch with Dynamica Rope, Outback Ideas recovery points, GME UHF, HID Low/High Beam, Lightforce Genesis HID Spots, Dual Battery Setup with rear power outlets, ARB air compressor in engine bay, ~30L Watertank mounted behind fueltank.
After having a chat with the boys and opposite lock, the pointed out a pretty obvious fact. If your in the bush and you loose your keys, you can always break a window and your UHF still works if its wired straight off the battery. However if you loose your keys in the middle of nowhere and you run of the accessories, your screwed as you cant turn the UHF on without car keys.
ozwap makes a point below about direct power from battery.
by ozwapet2 on Tue Apr 13, 2010 5:34 pm
3. still enables your UHF to switch off when you remove the key ( although it would be simple to rig a switch that bypassed the relay so you could have it on all the time - handy in some situations )2008 D4-D Prado GXL with extras.
High Country Huts www.hutsvictoria.org.au
ozwapet2
A couple of relays hooked up to open continuity and/or close continuity simultaneously on multiple wires would allow for the unit to be powered off the main battery, and shut down when vehicle not attended.... ie.... key removed. An overide switch for emergencies could be incorporated in the case that keys were lost. Best of both worlds, and would only cost a few extra dollars in an extra relay and switch.
Might be worth a thought?2008 Diesel Prado with extra stuff added. I drive it on the road and other places too.
Originally posted by DavrosThe above could easily be done in conjunction with wiring the unit up to the accessories as well.
Might be worth a thought?My Rig: 150 GXL D4D, Tough Dog adjustable suspension with 60mm lift, Polyair bags, ARB Winch Bar, Warn Winch with Dynamica Rope, Outback Ideas recovery points, GME UHF, HID Low/High Beam, Lightforce Genesis HID Spots, Dual Battery Setup with rear power outlets, ARB air compressor in engine bay, ~30L Watertank mounted behind fueltank.
With my previous vehicle, which I had for years, I ran a 4mm wire directly from the deep cycle battery to the uhf, and an earth from the radio to the body. Use an in-line fuse to protect the radio. Never had a problem and no static either. Also wired up the radio/cd player direct to the battery, so I could use it anytime without the key in the ignition.
A couple of times I left the radio going for hours, no problems.
Yowie.
mine is not connected to aux. i just turn off/on when needed. I don't have on that much - find the BS pretty bloody annoying. use 4x4ing or on highway sometimes. so I don't find it an issue.150 GXL Diesel (white) 09/10. ARB Deluxe bullbar colour coded, Lightforce 240 (HID), Winch, Tuffdog suspension, Mickey Thomson ATZ, tint, UHF, airbags, compressor, dual batteries,... and more stuff.
