BLUETOOTH CODE
  • BLUETOOTH CODE
    Hi, I've just had a GME CB radio installed in my new GXL and because I'm presuming the battery was disconnected my phone keeps asking me for the 4 digit code to re-connect to the bluetooth. I have absolutely no idea where I would find this code as the phone was set up by one of the salesgirls at Toyota. I'm pretty sure she gave it to me but I have no idea where to find it now. Do I need to ring Toyota to find this out? Any advice much appreciated!
    2010 graphite Prado GXL diesel turbo. ARB Bullbar, IPF driving lights, tow bar. Snorkel. GIC camper trailer to follow me wherever I go.....
    Re: BLUETOOTH CODE
    The settings within the radio may have been lost when the power was disconnected, meaning that whatever the code was in the radio has returned to default, not sure - but would be something like 1234.
    With assessories on, refer to the Prado owner's manual and follow the instructions for setting up the connection to your phone.
    From memory (unable to check at the moment) if you press the green telephone button once, and then use the left side control knob to scroll though the options and the center button of that control knob to select - you should find all the information you need for bluetooth code, connecting a phone and entering quick dial numbers.
    Hope that helps in some way mate.
      Re: BLUETOOTH CODE
      I think it is 0000 from what I have seen in mine.
      Regards
      Crisp Image
      GX 150 with 3rd row seats, Milford Cargo Barrier, factory roof racks,Tekoncha P3 & a duel battery system..
        Re: BLUETOOTH CODE
        the toyota will more than likely be 1234, the phones are normally 0000.
        [b]Rob[/b]
          Re: BLUETOOTH CODE
          i think mine is still set to 1234... um, i mean - no it's something else...
            Re: BLUETOOTH CODE
            Hey thanks guys, it's sorted now! I didn't realise I had to completely re-pair the phone instead of just trying to put a code in. Doh!! Hubby and I thank you!!
