Hi. just wondering how larger engle can be run on the rear 240volt inverter plug.
Rear 240 volt outlet
This topic is closed.
Re: Rear 240 volt outlet
The inverter in the rear of the 150 is rated at 100W. Unsure if that is a peak or a constant load rating - probably peak!
Anything over a 100W fridge would probably blow your fuse protection!
Bare in mind though, that the starting currents draw by motors can be upto 7-8 times the rated running currents... So its probable that compressor startup cycles will affect the operational conditions.
If you use the search feature of the forum, you'll find that the inverter has been covered in a few posts already!!!
EDIT: Your user manual will probably recommend "low wattage" consumers... Meaning, phone chargers, small laptops, etc...2014 D4D 150 GXL Automatic - CHARCOAL
