Optima Yellow Top D31A
  • Optima Yellow Top D31A
    Has anyone tried to fit an Optima Yellow Top D31A battery in place of the original battery.
    I have measured the space and its looks like it would fit - just, maybe!!
    Would love to here from some one that has done it and can confirm it fits. Not keen on buying a $400 battery only find it will only fit my boat, and I still need to buy a battery for the Prado.
    Pinko
    PINKO
    Prado 150 D4D, Bilsteins, OME Coils, Air Bags, TJM Bulbar, Avenger 9.5 winch, Lightforce HGT's, Kaymar rear bar, Sidewinder Dual Battery Kit, Drifta Draws, Window Tint, Transmission Cooler, Scanguage, Caterpillar Water Separator.
    G'day Pinko. What vehicle is this going into? A mate has a D31M installed in his 120 D4D which fits OK (same size as D31A, on Blue top with accessory posts) I have the D27M which is a bit shorter (308mm vs the D31 325mm).
    Regards
    Craig
      Sorry it's a 150 D4D,
      Figured as I posted it in the 150 electrical section I didn't need to point it out, that said I often read by the New Post tab which means its not all ways obvious.
      Thanks for the reply. If I do take that road and it doesn't fit, I have a friend with a 120 that would be happy to take custody.
      PINKO
        Why not measure it before you buy it?
          Like I said, I have measured but it is close, very close!
          Hoping to hear from someone that has done it.
          PINKO
            I have the ARB battery tray fitted and the optima blue top D34M just fits neatly, only problem is the 55A/h capacity. This however is offset by the quick recharge time and the 180A/h VRLA UPS battery I have in the rear. Measurements for the D34M are 254x174x198mm and it weighs in at just under 20Kg.
            SOLD!!! 2011 Prado GXL manual in silver
            ARB Winchbar, Lightforce HID's, 3" SS Manta exhaust, 3" Monster Rides suspension system, Tracklander roofrack, Ostrich wing awning, Kaymar dual wheel carrier, Gturbo stage two Grunter and reprogrammed ECU. Trackabout Dakar SV Extenda. Purchased 2017 Landcruiser 200 Altitude.
