ARB Deluxe Bar Parking lights
  • ARB Deluxe Bar Parking lights
    I've had one of the parking light globes blow after only a few months . Do you have to remove the plastic light assembly to replace the globe ? Is there an LED replacement available ?
    Ross
    Common issue, go LED, checkout my build thread
      Theres 2 screws on the inside, you can get them by removing the side cover plates or partially removing the wheel arch liner, they are alot easier accessed on the 120 as the grill lifts with the bonnet.
      I fitted LED's to mine as soon as i got the bar (add the 2 weeks shipping from China), will post a link later if you still need it.
      [size=1]2011 GXL D4D Auto | ARB Deluxe winch bar | Bilstein/Ridepro platinum lift | MT ATZ P3's | Dick Cepek Torque rims | Airtec snorkel | Lightforce Genesis 55w HID | GME UHF | 55w HID high beam | Rhino Rack bars & Cage | ISI extreme rack | Dual Optima Batteries | Milford MXV-70 cargo barrier | ARB onboard air | Prodigy P3 | Drawers & Black widow fridge slide | Waeco CF-50 | Kaymar rear bracket and LED light | EscapeGear seat covers | Sandgrabbas and more...[/size]
        D4D yours look the part, what price are they if you dont mind ?
          G'day , I'd be interested in the LEDs also, was also wondering the other day if hid lights could go in them?
          Thxs I'll keep an eye on this thread ..
          2010 Prado GXL D4D Auto , BFG A/T , DVD Console , Tekonsha P3 , Projecta Dual battery system , Piranha dual battery tray..
          Jayco outback expanda
            http://eziautoparts.com.au/lighting/...mm-x-24mm.html
              Heres the link where D4D detailed his LED upgrade along with a couple of other options using LED bulb replacements.
              http://www.pradopoint.com/showthread...l=1#post265370
                Thanks guys, i already replaced one that started to "blink" 3 of the LED's, if anything happens them again i'll replace with this unit.
                cheers
                  Hey D4D. Just wondering if your bar had the brackets at the back of the park lights and if not, how did you mount the LEDs? The LEDs don't have the hole through them which is how the current parkers are attached and I want to make sure they are fitted securely. Hey D4D. Just wondering if your bar had the brackets at the back of the park lights and if not, how did you mount the LEDs? The LEDs don't have the hole through them which is how the current parkers are attached and I want to make sure they are fitted securely.
                  Stephen Bloomer
                    Read my build thread or the link posted, it is all in there...
                      Apologies. I was looking at your MySwag link instead of you PP build.
                      Stephen Bloomer
                        Has anyone fitted these LED lights to the newer bar that does not have the metal backing plate to mount the light on?
                        Stephen Bloomer
                          Is there a simpler method than changing the whole assembly . Couldn't you just use a LED replacement lamp ?
                          Ross
                            Putting in LED globes are the quick fix that should help with the problem of globes blowing, but putting in a full sealed LED would give a better result IMO as this would be water and dust tight as well.
                            Steve.
                            Stephen Bloomer
                              I went the bright light Led globes today. Sealed up the lenses with silastic..
                              [CENTER][B][U]Matt
                              [/CENTER]
                              [SIZE=2]
                              [/SIZE][CENTER][SIZE=2]
                              [/SIZE][/CENTER]
