150 dual batteries with optima d27f 66ah
  • 150 dual batteries with optima d27f 66ah
    Hey there everyone. Thought you may be interested in the dual battery install I recently did in my brother in laws 150 prado.
    He wanted a larger capacity than is normally fitted in the 150, mainly to run his massive engle fridge for longer without deeply discharging the battery. So after a few measurements we ordered an optima d27f with a usable capacity of 66ah.
    Now this battery is a big bugger at about 305mm long so a little bit of thinking was required to make it fit.
    This is the bracket I knocked up.
    The batter sits on its end and the bracket supports the entire end of the battery to spread the load. The tray is bolted to a heap of factory nuts serts it the guard.
    Now in the pics the battery looks like it sits up a mile, but it fits perfectly and just (and I mean just) touches on the foam bonnet liner.
    Hope the post turns out ok I'm doing it at work on my iphone.
    Any questions just ask
    Shane
    I thought you would've got that size battery sitting it's normal way up in the 150 making it easier to retain and access the terminals? I'm aware that these batteries can be installed in this orientation, but not sure how they would last in a 4wd. I don't think I would be keen on doing rough tracks with a battery mounted this way. Hope I'm wrong... How much surface area of the battery is actually supported? Just one edge of the cell cylinder of the D27f? Or is it shaped to support more?
      If you were to put the battery the normal way there would be a fair bit of manipulating of the aircon pipe required. The entire end surface is supported the way I've made the battery, it's solid as a rock. And the optima batteries are designed to go in any orientation. The dual battery kit from piranha for the current jeep wrangler actually uses 2 optimas on there side to fit the space.
      So should be all good
      Thanks for your comments.
      Thanks. Shane
        I've got a D27F mounted normally in that space , it required minimal movement of the aircon pipe
        If the wind don't blow, the world don't suck and we all fall off
          Having said that ^ you've got me thinking , a quick look revealed I only have a D34 in that space
            I have a Optima D27M sitting right way up in that position. Plenty of room. Its sitting on a TJM tray. A/C pipe moved the normal amount.
            2012 GXL White Prado. TJM BUllbar, TJM Winch, TJM Side Steps and Bush Bars, Black Widow Drawers, MSA Fridge Drop Slide, TJM Dual Battery Setup with Optima Battery, TJM Snorkel, Black Widow Roof Rack with Fred's Arm & TJM Awning, GME 3340 UHF, HID Drivivng Lights, TJM full underbody protection, Morosso Oil catch can, MSA Canvas Seat Covers, Kaymar Rear Bar with Dual Wheel Carriers. Cooper STMax tyres on original rims.Scanguage II.
