any one had any thing to do with the seat belt alarm as if you had it unlocked or someone undid there's whilst driving the alarm went off ,all of a sudden it is not going off any more if undune or not put on .
seat belt alarm
The alarm is activated by someone sitting in the seat and not buckling up the seat belt, seat has sensor built in which activates when someone sits on it, if the seat belt buckle is not put in to the retainer another switch does not operate to cancel the alarm.
Note, I think the alarm info is also feed into the SRS system, so if the seat is not detecting anyone sitting in it the airbag won't deploy, so would be worth getting it fixed if you have an airbag for that seat.
Check all plugs etc are connected under the seat.
LeighLast edited by LeighW; 25-02-2013, 10:02 AM.HKB Electronics, manufacturer of the Alternator Voltage Booster, Silver 2008 D4D,Lifted,Underbody protection, Alternator Voltage Booster, Tiger Z winch, Lightforce DL, Air Horns, Tanami Drawers, Drop down fridge slide, Outback cargo barriers, Rotronics dual Battery system, Polaris GPS, HF/UHF/VHF, Radio speaker combiner, Long ranger water tank, Diff breathers, Inverter, Snorkel and others
