Hi Guys,
I have a Hayman Reese Towbar fitted to my 150 Prado.
Today i hooked up a trailer and noticed my Hazard lights would breifly flash once then not turn on at all. My brake lights also wouldnt work on the trailer.
I hooked up a second trailer and noticed that when i turned the hazard lights on the brake light would flash as well.
I tried a 3rd trailer and everything worked except the brake lights.
I used a test light to check everything and it all seems fine. hazards work, brakes and lights all light up the test light. I also used the same earth point as the trailer plug uses thinking it may be a fault in the earth..
Any suggestions?
Any suggestions?
