What is this powered fitting
  • What is this powered fitting
    I'm in the process of installing a dual battery set up & was pulling panels apart to see where to install cig sockets when I pulled out what I thought may have been a bolt cover. Instead it's a blanked off power connection. See the photo. I have a 2012 Altitude diesel. The connection is on the drivers side in the rear compartment. There isn't one on the passengers side. Does anybody have any idea what this is and if it could be used?
    has come up a few times in the past, I don't recall an accurate answer. maybe a temperature probe for the climate control ?
      I'm pretty sure that is a temp sensor for the rear climate control.
      [LEFT]Silver 150 Facelift
