Hi guys, I have a 2010 Prado 150 D4D and have just noticed the fuel gauge doing strange things. I filled it up the other day and after driving for sometime the fuel gauge got down to 3/4 full and then lower as I drove further, all good so far. It was just above 1/2 full when I stopped driving for the day and when I got back in I noticed it was back at 3/4 full again, I then drove a couple of hours and it when down to nearly 1/2 again. Today I drove it again and it was on 3/4 full. It's only done 114,000 kms surely it can't be too much. Has anyone else heard of this happening? Cheers
Fuel gauge all over the place?
Diesels are pretty consistent with fuel usage (towing aside). I tend to use my odometer/trip meter to decide when I fill up. I have done so ever since my old 80 series got stuck at 1/4 tank and I ran out of fuel.2010 Prado GX 3.0L TD - "Paul" - TJM XGS 40mm Lift Kit, Firestone Coilrite Airbags, 5000kg Rated Front Recovery Points, Sure Power Battery Isolator and Dual Battery Setup, Airtec Snorkel, HID High Beam Headlights.
hi all I am new to this forum and have had this problem. I first noticed it when I change the exhaust over on my 09 Kakadu. for shits and giggles when I filled up next I tried rocking the car once I had filled the tank and noticed that there was a big air lock and I have a feeling this is what was causing the fuel gauge to play silly buggers. I didn't have any problems with the fuel gauge dropping and rising after that
Mine has been doing this for the last 100,000km. The gauge works for the first 1/4 and then drops to 1/2. It then works again when 1/2 fuel used. Sometimes it bounces a bit between the 2 points.
I have had both senders and cluster replaced. Still no joy.
The regional rep has looked at it (in December) and I am still waiting for Toyota to book it in to do something about it.Silver 150 GXL V6 Auto: TJM T13 bull bar, Avenger Mako TDS 9.5 winch, 2" lift - Bilstein shocks King springs, factory tow bar, Piranha battery tray, Red Arc isolator, E-Nex DC24MF battery, GME TX3540 UHF, ARB 47L fridge, ARB fridge slide, IPF spotties, Tekonsha P3 brake controller
