I have a dual battery set up with Redarc SBI 12 and Optima D34. Goes to panel at back near Jack with dual usb, , cig & engel. Have an Anderson plug that runs down chassis next to tow bar.
In the set up the auto electrician did, he has installed a 20 amp circuit breaker. (I know, not the favourite approach by a lot of people on Pradopoint). I connect a Dr Air Pro compressor at back via the Andersen plug rather than by clips to battery (have leads configured so I can do it both ways).
Anyway, under load after a while, the circuit breaker cuts out. Checked with the auto electrician and he reckons that the circuit breaker is too small, says he only installed it for a caravan load, not for a compressor. (By the way, no problems with compressor when connected direct to battery).
It's only $12 for a 30 or 40 amp circuit breaker from Supercheap so I was gonna have a go at changing it myself.
Always nervous with auto electrics, any advice for changing it over appreciated ie do I need to disconnect from battery, any issues with SBI 12, can I just leave everything connected and just swap over
