Hi guys,
I'm a long time follower, first time poster, so G'day and thanks for all the info so far!
I've just purchased a 150 series and I'm in the process of adding a second battery. The install is going well so far, and I've been reading through the dual battery posts for a few tips and tricks, which has been useful.
The dual battery kit I purchased came with a long power cable to join the main battery to the isolator and then on to the second battery, and a short black earth cable which I plan to earth via the vehicle body. Initially I thought I would piggy back the earth cable off an existing earth bolt (I spotted the horn next to the air filter which looked suitable) but now I'm wondering if I could/should utilise one of the spare threaded inserts in the engine bay to provide an earth to the dual battery on its own.
Can anyone advise as to:
A) is it OK to piggyback off an existing earth point,
B) can you utilise one of the empty threaded points mounted in the engine bay to add an additional earth point, and
C) if the answer to B is yes, will any correct size bolt do or does it need to be a specific earth bolt (I notice the ones currently in place are marked with an 'E').
Thanks.
Peter.
Thanks.
Peter.
