Does anybody else have trouble with the usb plug thats in the center console not charging phones. Both me and my wifes Samsung S7 's and my old S5 it will either not put in any or if does will be stupidly slow.
2.8 centre console usb
Arb colour code deluxe bar, safari snorkel, lightforce venom HID's, GME uhf remote face, redarc tow pro, redarc bcdc 1240, pioneer platform, 40" curved light bar, dual battery, 3" SS exhaust, EGR mod, trans cooler upgrade, provent catch can, scangauge 2, diesel care secondary fuel filter, Tin's bash plates and actuator gaurd, 2in Bilstien and kings lift,Tags: None
Yep thats normal. I was told when i picked mine up that it didn't charge but it will run the phone and charge very slowly
Sent from my SM-G900I using Tapatalk2014 VX D4D. Dobinson 2 inch lift. TJM T3 Bullbar. rhino platform. TraxRax. Maxtrax. Dual batteries. GME TX3450.
Phone charging is pretty complicated these days, especially if you want to do it quickly. Many Android phones use various versions of Qualcomm's Quick Charge protocol which lets the phone and charger negotiate over the data lines. Even getting a higher current cigarette lighter -> USB may not give you the results you want. I use an Aukey car charger as they implement Quick Charge (some V2.0 and others V3.0). With one of those I can run my Nexus5 in sat-nav mode, with the screen permanently on and GPS permanently lit up, and it still manages to provide a net positive to the phone battery... i.e. the phone is more charged at the end of the journey then it was at the beginning. Every other car charger I've tried still has the battery slowly draining when operating in that high-power mode.
http://www.aukey.com/category/Car_Chargers
https://blog.oxplot.com/quickcharge/
I installed one of these and it seems to charge pretty quick.
http://www.solidkit.com.au/product/h...-on-and-lc200/
I put the outlet next to the DAC switch and grabbed power from the positive of the cigarette plug in the centre console.
Well thats a bit of a downer 62k car and you still have to buy an accessory to charge your phoneArb colour code deluxe bar, safari snorkel, lightforce venom HID's, GME uhf remote face, redarc tow pro, redarc bcdc 1240, pioneer platform, 40" curved light bar, dual battery, 3" SS exhaust, EGR mod, trans cooler upgrade, provent catch can, scangauge 2, diesel care secondary fuel filter, Tin's bash plates and actuator gaurd, 2in Bilstien and kings lift,
Originally posted by beatit99 View PostI installed one of these and it seems to charge pretty quick.
I put the outlet next to the DAC switch and grabbed power from the positive of the cigarette plug in the centre console.Arb colour code deluxe bar, safari snorkel, lightforce venom HID's, GME uhf remote face, redarc tow pro, redarc bcdc 1240, pioneer platform, 40" curved light bar, dual battery, 3" SS exhaust, EGR mod, trans cooler upgrade, provent catch can, scangauge 2, diesel care secondary fuel filter, Tin's bash plates and actuator gaurd, 2in Bilstien and kings lift,
Originally posted by 404pug View PostHow did you get to the positive of the cig. plug in the centre console?
I shaved the insulation off a few cm from the console loom connector, twisted on +ve to the usb charger, soldered it and taped up with leccy tape. The earth comes with a ring terminal that I screwed down with the motion sensor sitting under there.
Def a handy spot where I put it for gadgets in that front pocket and the phone up on a dash mount. With three kids and all the gadgets we take touring I'm considering putting in another one! Also prob change it over to an auxillary circuit once I do my dual battery install.
I use one of these in the front cigarette lighter outlet, it charges my Asus Zenfone 2 on quick charge. Could be an option for the rear cigarette lighter outlet also.
http://www.banggood.com/Qualcomm-Cer...-p-993678.html
or there is this one on special at the moment:
https://www.ozbargain.com.au/node/270201
Reviews on Amazon mention the Note 7 and also the IPhone 7.Last edited by paddyb; 12-10-2016, 07:19 PM.
Well had it in the dealer today there reponse was its not meant to be a charger, but then tested it and said it does charge.
To what i than screamed at the wife, yes we know it shows its charging but it may put 10% in 4hrsArb colour code deluxe bar, safari snorkel, lightforce venom HID's, GME uhf remote face, redarc tow pro, redarc bcdc 1240, pioneer platform, 40" curved light bar, dual battery, 3" SS exhaust, EGR mod, trans cooler upgrade, provent catch can, scangauge 2, diesel care secondary fuel filter, Tin's bash plates and actuator gaurd, 2in Bilstien and kings lift,
Originally posted by Hally View PostWell had it in the dealer today there reponse was its not meant to be a charger, but then tested it and said it does charge.
