Hi guys, I've scratched my head for a while now but can't for the life of me work out where to mount the redarc sbi12 in my 150 using existing bolt or screw holes.
I've got the arb compressor mounted in the passenger side so it's a bit congested down there. I would like to keep it close to the main battery as recommended but the big empty spot on the drivers side behind the air filter is very tempting. If I didn't use existing bolt holes is using tech screws a viable option ?? I feel they could rattle loose.
If you're using the sbi12 could you attach some pics of the mounting location?
I'm struggling.
Joel
I'm struggling.
Joel
