Dual batteries - vsr + solar
  • Dual batteries - vsr + solar
    Hello all,
    I am new to the forum and looking at purchasing a new 150 1GD. I currently have a GU Patrol and hoping to upgrade to the Prado. I have read with much interest about the dual battery setups and have a question that I am not sure has been covered. If I have missed it I do apologise but I am pretty sure I have read all of the dual battery threads.
    My current setup is a Redarc SBI 212 with push button override. I also have a permanent 130w solar panel on the roof rack feeding the auxiliary battery. It seems to work well in the Patrol and I haven't had any issues.
    My question is would this be effective with the 1GD? Would the current from the solar effect what the alternator output when running? I certainly think it would be great to top the battery up to 100%, something that seems to be an issue with the 1GD.
    If possible I would prefer a VSR setup as opposed to DCDC. I link batteries for winching and if I need an emergency jumpstart it's just the flick of a switch. I haven't carried jumper leads for years. I am waiting for a response from Toyota as to whether they can modify the alternator output through the ECU. I know Ford can reprogram for Ranger, I am hoping Toyota will be able to do the same.
    Hello again,
    I spoke with a Toyota Technician today in relation to the alternator, dual batteries with VSR and solar. I was advised that Toyota can't modify the output of the alternator through the ECU. He did recommend that with a permanent solar that a relay should be install from the panel to disconnect when the engine is running. It wont be too hard to install an ignition controlled relay to achieve this. That way I get the best of both worlds. Alternator charge when running and top up when the car isn't. If the car is parked undercover a permanent 240v smart charger will solve that so I always have an auxiliary battery in top condition.
      Hi,
      This is already being covered in the 150 section, I would suggest you do a search for dual battery system for the 150. You don't need to disconnect the solar charger when the motor is running.
      LeighW
        Leigh,
        Thanks for the reply. I thought I got all dual battery threads, obviously missed one.
          See http://www.pradopoint.com/showthread...up-for-2-8-1GD
