Hi all, found I had some serious algae built up in the windscreen reservoir that blocked basically everything from the pump to the end nozzles.
So have flushed it all out and have replaced the pump and T-Piece splitter near the end nozzles.
Now I am getting water to the windscreen but not at full pressure and it is just continuous no matter if the windscreen wipers are activated or not.
Cannot see any leaks, so am not sure why it should continually run.
Any ideas would be appreciated.
Vegie
Vegie
