Traction Control on GXL's - Can it be turned OFF?
  • Traction Control on GXL's - Can it be turned OFF?
    Guys....
    Sorry for this, but can the Traction Control be turned off on the GXL's and where is the switch located ?? :roll:
    Re: Traction Control on GXL's - Can it be turned OFF?
    there is a switch above you left knee. You can turn it off for 4wding, but it turns itself back on above a certain speed.
      Cheers for That
      I assume it only turns OFF the Traction Control and not as well as the other electronic aids ???
        If you press and hold it down for about 5 seconds it will also disable the stability control.
        Once you go over about 40 it reactivates.
        [size=2][color=#4000FF]2009 GXL D4D Manual
        [/color][/size]
          Is there any way to turn it off so it doesn't reactivate above 40?
          2010 White GXL Diesel Manual, 2" Dobinsons Lift, 275/70/17 Maxxis Bighorn 762s, Front Air Locker, Delux ARB bullbar, Lightforce Spotties, Safari Snorkel (to come), Dual Batteries, Uniden UHF, Aluminum mesh roof rack, Sandgrabbas (on their way).
            I changed my mind and removed my post. Curious why? Look there: http://www.pradopoint.com/showthread...upgrade-in-GXL
            darecki
            Sooky & Banned
