I called into a exhaust shop today to ask there advice on a slight note for the Prado. The guy suggested cutting out the crapola factory beast like muffler and replacing it with a smaller magnaflow unit. Anyone done anything similar? I want just a slight noise with nothing loud and farty he said should sound very nice ????$350 might be worth giving it a crack.
Has anyone replaced big factory muffler for sports type?
Yes. Lots of us did. There are a couple if threads on that subject, but have a look at my rig build where I have detailed how I went for me on the D4D. But if you pay more than $200 you have paid too much. I paid $150
SteveStephen Bloomer
Originally posted by smakb View PostYes. Lots of us did. There are a couple if threads on that subject, but have a look at my rig build where I have detailed how I went for me on the D4D. But if you pay more than $200 you have paid too much. I paid $150
Steve
Was yours a magnaflow muffler or another brand?2010 Kakadu with all the usual stuff.... Build up thread below
Mine was the muffler that the exhaust guy fitted. Have no idea what brand, just that it was a straight through and it helps helped a lot. That was on a D4D though.
If you come visit me at work Daz you can have a listen of mine, mine is a full system though.
Otherwise the guys at RAMP were very good and knew what they were doing... (if you wanted a recommendation)
mine is a 120 though, but should be similar.2004 Prado GXL. v6 auto, ARB deluxe bar, exhaust, 2" EFS lift kit, Outback Acc rear bar,
More to come!
Originally posted by timmay5.7 View PostIf you come visit me at work Daz you can have a listen of mine, mine is a full system though.
mine is a 120 though, but should be similar.2010 Kakadu with all the usual stuff.... Build up thread below
Tyres are noisier than the exhaust...
I originally had a magnaflow 2.5 cat back, but it was too drony, and I didn't like the way it went into the 1 pipe from the 2.
had it changed to a larger muffler and then a resonator at the back, much better.2004 Prado GXL. v6 auto, ARB deluxe bar, exhaust, 2" EFS lift kit, Outback Acc rear bar,
More to come!
Originally posted by KAKADAZ View PostThanks Timmay....any drone? I would do a full system but it's a mostly straight 2.5" stainless system from the factory.
I assume yours is a petrol KAKADAZ, and you will have the drone/resonance noise unless you have a second small muffler at the rear.
Have a stainless system on my GXL petrol, back from the 'Y' junction of the 2 manifold pipes. The muffler is about the same length, but about 19cm wide and 12cm high, through to a small muffler at the rear. No drone, however, the noise is deeper, and mid range acceleration is a bit quicker.
The installer told me that Toyota fit some sort of wire gauze in the 'Y' piece, so he removed this from mine.Last edited by yowie; 29-08-2012, 03:33 PM.
