Hi guys, as the new FJ is about to be available in Australia for under a week, I thought it might be a good idea to start a discussion between the two vehicles. Both are pretty much similar in power (FJ only come in petrol in Aus, V6 4000), similar build ( the FJ suspension and chassis is adapted from the Prado), the FJ come standard with a rear diff unlike the Prado which comes standard with a centre diff. And the next obvious difference is the fuel tank size (ie. touring range) where the Prado wins hands down. However, despite their minor differences, the FJ is priced at only $50,000 which is much less when compared to a GXL (as FJ doesn't have the option of KDSS and CRAWL). Now the question to answer is why should someone pay almost $20,000 and more for a Prado GXL where the FJ might be able to provide a similar 4X4 experience.
Prado vs the new FJ
Re: Prado vs the new FJ
When Toyota were discussing the release last year, they were talking 40K drive away.
At that point I was interested as a daily driver replacement.
Now it is closer to release they have since said 44990 plus onroads and you mention $50K, I think I will explore other options, as for 50K (or a little more) I can buy the new 70 series wagon with turbo diesel V8.[img]http://members.optusnet.com.au/~stella_and_col/mypic49.gif[/img]
Originally posted by PradoDudethe FJ come standard with a rear diff unlike the Prado which comes standard with a centre diff.
Originally posted by PradoDudeHowever, despite their minor differences, the FJ is priced at only $50,000 which is much less when compared to a GXL (as FJ doesn't have the option of KDSS and CRAWL).
Originally posted by PradoDudeNow the question to answer is why should someone pay almost $20,000 and more for a Prado GXL where the FJ might be able to provide a similar 4X4 experience.
1: Size of the vehicle and its bootspace
2: Comfort?
3: Electronics?
4: The fact that the FJ has a 30kg limit on the front end? Which means no steel bullbars etc
I haven't seen the FJ yet, but when I do (next week), I'm sure I can give better and more accurate reasons for the 10k difference.
Cheers[COLOR="black"][b]William[/b][/COLOR]
From an article in the Age/SMH drive last week.
THEY said the FJ doesn't have full time 4WD. ( ie no centre diff ).
So it's gone back to the system of 2WD only drive then you engage the front diff if you want 4WD.
Apparently they come standard with a rear diff lock and traction control.
So overall probably a better offroad system than Prado however doesn't look as practical for long distance touring. ( smaller tank,, no diesel, and less room in the cargo area )Cheers, Wayne
Thanks for the clarifying Wayne. I suppose they may be right since they've had the car to review? I've also read that the rear diff lock may be an option. Lots to clear up when at the dealership!
Originally posted by amtsYou can't put a bullbar on the FJ.
The FJ comes with 265/70R17 tyres as standard = much better choice of tyres without jumping through hoops to change from 265/65R17 on the Prado.
And the touring range/fuel tank size can be fixed with a long range replacement or aux tank which I believe Rob A or FJ Cruiser have mentioned. Seeing as these things are a couple of years old in the USA there are bound to be a heap of aftermarket accessories available albeit on the other side of the world.
I reckon Snaga might have some pics to put up of a modifed FJ.
This review seems to compare the FJ to the Prado a little. http://www.anyauto.com.au/2011-toyota-f ... er-review/
MDS69: The 30kg limit bulletin can be found in this thread: viewtopic.php?f=1&t=9842
Check this out too: http://www.fjcruiserforums.com/forums/p ... -rips.html[COLOR="black"][b]William[/b][/COLOR]
It looks like Toyota's answer to the gay Jeeps. Something Brian Kinney would drive in that Queer As Folk SBS gay show that was on television, in place of his gay Jeep. Except the Toyota has more bling. Eeeeek!
Originally posted by barryswansonThe FJ would hands down be the ugliest car ever made.
Check out: 100 ugliest cars or even 15 Ugliest cars ever made[B][SIZE=4]ntp
Is it the colour thats putting you off? I've been told that yellow is no longer available. How about black?
With some aftermarket accessories, I reckon the FJ would look dangerous :shock:
For the record, the ugliest car ever made would have to be the pt cruiser :shock:[COLOR="black"][b]William[/b][/COLOR]
Can you have traction control on all four wheels without a centre diff? I wouldn't think so - Prado 120 turns off traction control with centre diff lock on.2008 D4D and a very long dog
[url=http://pradopoint.com/viewtopic.php?f=38&t=5318&p=74777&sid=afe8667706bc76d907c8fa81464352d4&sid=1d0b38233e6e0a28f012b5561ec1d59e#p74777]Our Prado[/url]
Originally posted by ntpOriginally posted by barryswansonThe FJ would hands down be the ugliest car ever made.
Each to their own i guess.
Couldn't possibly consider an FJ until it comes in diesel anyway.
