Hi guys. I got new rims and tires put on my 150 and the factory wheel studs aren't giving me enough thread engagement. I know the factory studs are m12x1.5 but I can't find anything on length. I live in the philippines so there aren't really any parts stores that could work this out for me I'll have to tell them exactly what I'm looking for. I need about 12-15mm longer stud front and rear. Thanks for the help in advance I searched and came up empty.
Longer wheel studs needed
The current stud length on the 150's is about 25mm or so, and u want another 15mm? Are u putting wheel spacers on or something?[I]cheers..... Rob (macca)[/I]
[B][I][COLOR=Green]Car-2: 1993 Suzuki Vitara 4Dr (modified for Playing) [/COLOR][COLOR=#ff0000]Now Retired[/COLOR][COLOR=Green][/COLOR][/I][/B]
Catalogue:
http://www.noelsautoparts.com.au/Nic...Nuts%20Web.pdf
Order from these guys:
http://www.noelsautoparts.com.au/Wheel Studs & Nuts.htm
or you could also try AL-KO they supply studs and nuts.
Or Snake Racing, but they'll want your first born.... like $240 a set.
