    Well that's my experience, YMMV. I had D64s on my 90 and they were great but made in Japan, not Indonesia.
    Had my 697's fitted early this year, just before I towed the van to south-west W.A. and back. Tyres are stamped 'Made in Japan"
    No problems with the tyres, except that the tread collects a lot of small stones.
    • Originally posted by yowie View Post
      Well there you go, maybe why I got my spare relatively cheaply, it must be a parallel import. The other 4 were fitted by the dealer, also made in Indonesia. I have small consolation in that I only paid for 1 of them.
      And yes, they do tend to collect lots of small stones.
      • Polished the Prado after the trip to W.A.
        I had a protective coating applied when I purchased the Prado new in 2010, it lasted well, however, on the return trip after I washed off the dust and dried mud, I found that the bonnet and roof were covered in hundreds of small red/brown stains that would not wash off. Not sure, but may have been small spots of tree sap that stuck the red/brown dust onto the surface.
        The spots were not on the van. The van was driven along some dirt roads as well but no red/brown spots on the roof. The Prado was driven some places without the van attached.
        The polish is Starbrite Premium RV Polish, can be used on vehicles, vans, motorhomes. Made in America, for use on fibreglass, metal, plexiglass and painted surfaces. The polish contains polytetrafluoroethylene (PTEF). Very slippery surface on the metal body and plastic wheel cover. Will see how it lasts.
        Bought it from a Road Tech Marine (RTM) store in southern Sydney.
          Did you purchase from a Bridgestone dealer, or another?
            We use them at work on our fleet and i have them on my 90 with no complaints.
            I like them but was also looking at the BFG ko2 but they werent available around home also 18" isnt exactly common around Toowomba apparently so choices a little limited
            sounds good.
            Originally posted by Ian Reid View Post
            They initially quoted 390 a corner and was at $50 off each when i mentioned they were thru a lease company and all went out the window. Will know what they cost when it is processed through lease. At least they didn't query why i was removing the half worn Dunlops which i will try to off load when i get a chance.
            I got mine a bit cheaper because the Bridgestone Technical Field Service Manager for Vic organised it for me through a local Bridgestone dealer. Their own shop at head office couldn't do it that cheap, go figure! I will say their service when I raised an issue was impeccable, they even took me and the Kaka over a weighbridge to check weights and determine optimal inflation pressures. For my Kaka they said 43PSI was ideal but I run them at 40PSI, the extra 3PSI made the ride just a bit too harsh.
            ETA: They do look good when brand new on a frehly painted rim :-
            i got quoted $264 a corner fitted from bridgestone dandenong in size 265/65/R17. think its a good price?
              The spare was purchased from Donellan's who are a Bridgestone dealer, don't know who the dealer used for the other 4.
              Not sure as mine are a 265/60/R18, 18" are exxy.
                lol right, im posting in the 150 thread.
                looks awesome tho mate!
                • Finally came to a decision and put a deposit on my Old Man Emu 2" lift.
                  Spilsy
                    That's OK, not all 150s have 18" rims so hopefully someone else will chime in. The rim was freshly painted in that pic, 2 pack paint with a satin clear finish.
                      I paid $265 or $269 (I can never remember which one) for mine in that size.
                      Spilsy
                      • Started the install process for the 11XP. Since I was on my own I took the cover panel and grille out to check there was enough space to drop the winch in. Should be ok not that I doubt the info given me by TJM. Then I took off the winch cover plates and bolted the hawse in place and checked there was room for the shackle block in lieu of hook. Given the most tedious job is usually making a bracket for the isolator and mounting the isolator I tackled that and mounted it up near the battery, fitted a couple of M5 rivnuts in the panel that runs across the top of the radiator. Trimmed the cover plastics and it works pretty well. Then I took the winch out and looked at it. Quite happy overall. Mostly though I did the looking bit. Broke two plastic clips but they were a bit dodge anyway. Oh and I put a couple of rivnuts on the bottom of the plate of letters and numbers. So I don't leave it behind like someone else I know.
                        • Which reminds me, another thing to do...
                            looks really great mate. probably even better in person. i really want to change the look of my wheels to something similar. thinking of plastidipping it to just black or something similar. this gon be maad
                            sounds pretty good. might just go with it. thanks mate
                              You can buy cans of paint from the auto parts store and do it yourself but I had 4 wheels with an existing paint job I needed to match. The previous owner told me where he got them done so I just let them match it up.
ID:	652034Click image for larger version
                                Did my first 4wd trip with the mates... So impressed with the car. Also so happy I did the NSW toyo land cruiser club course... Apart from a high risk rutt sided by a big wall of rock that I didn't want to risk my doors on, the car had no worries, and took on some awesome terrain.
