G'Day, need some advice, if I may ask...
We've had our early 2012 Prado 150 D4D GXL for nearly two years - we were fortunate to pick it up second hand for a very good price, with very low km's. Prior to this car, I was of the mindset of buying a car and turning it over reasonably regularly (3 years or so) to maximise it's second hand value and keep us in a nice, newish car. This works pretty well when you don't add things to it and keep it stock standard. With the Prado, we've added LOTS to it already and intend to keep up the modifications and additions - I don't believe you see much (if any) return in value on the second hand market, for 4x4s with modifications done to them - in fact, I presume like others, I was looking for a stock standard one so I could be the one to make the modifications and know that it hadn't been driven as though it was a submarine to the tip of Cape York in the Wet!
Anyway, I've decided that with this Prado, we'll err on the side of driving it until it dies... I need some advice on some of my plans to maximise its life expectancy!
Note that we occassionally tow a 1200kg Offroad Camper (Camprite)
Already fitted:
ARB Deluxe Winch Bar
Bilsteins front and back with Ridepro springs (50mm lift)
Dual battery (REDARC controller) (note, no special battery tray, as far as I can tell...)
Safari Snorkel
D697 265/65/17 LTs
Redarc Tow Pro
Transfer Case and Actuator Guard (TG150) by Brains
Toyota Tow Bar
Soon to be fitted Parrot Asteroid Smart - can't wait to install that one, though I can't imagine it will impact on the life expectancy.
I change the oil with the stuff Toyota sell every 5000km and replace the oil filter and get the thing serviced with Toyota - so far so good.
Please provide your thoughts on my planned "maximum life" extensions:
Extra RACOR fuel filter prior to Toyota filter?
EGR Blanking plate (with hole/without?)
Provent 200 Catch Can?
Battery tray (minimise risk of cracked inner guards?)
Diff breathers?
Get injectors checked at around 60,000km? Only done about 35,000km at this stage.
Appreciate any other recommendations or your input and thoughts/comments to keep this running until we are getting around like the Jetsons.
Already fitted:
Safari Snorkel
D697 265/65/17 LTs
Redarc Tow Pro
Toyota Tow Bar
Diff breathers?
