A little while ago while we were driving down the beach on Moreton Island the TRC/VSC seemed to give up the ghost. We'd been driving for quite some distance in very soft sand and I'd forgotten to turn the TRC/VSC off so it was kicking in pretty frequently as we moved around in the loose sand. Eventually I noticed that this light came on and it has stayed on ever since:
![](http://i289.photobucket.com/albums/ll212/andoland/IMG_20141122_110123_780.jpg)
Looking in the manual is says this is the "slip indicator" and "It may indicate a malfunction of the VSC or TRC system. Consult your Toyota dealer."
I think that the TRC and VSC are now not working but of course the only way I'll know is if I break traction and they don't kick in. Before I head off to Toyota and potentially pay them a large sum of money to fix it I wondered if anyone else had come across this and if there might be some easy things to check first. I looked in both fuse boxes at the time and couldn't see a specific fuse for this and I also looked under the vehicle to see if a wire or sensor might have come off or broken but there was nothing obvious. In any case the ABS still seems to be fine so I think this would rule out a broken/disconnected wire or sensor.
So any thoughts out there from the collective Pradopoint wisdom on what to check before I turn the car over to Toyota?
Ando
Ando
