Odd question, can you set the indicators to flash 3 times when you half press the indicator? I noticed this is a "feature" on the Kluger Grande i test drove, as well as the commodores at work. not a big thing but i thought it would be standard?
150 GXL Indicator Flash
There's a pretty long list of things, most of which seem useless to me. Some things that might interest people below. I'm going to try and gett the ones with asterisks changed at our first service.
Wireless door lock
- only unlock drivers door with remote on first press, twice for all
- auto-relock time if you unlock but don't open a door
* beep when you wireless lock/unlock
- wireless buzzer beep volume
Power Windows
* close windows using wireless key (2nd press?)
* open windows using wireless key (2nd press?)
- enable/disable "auto" mode for each window
Illuminated Entry
- how long the lights stay on before fading
- lots of other things
Air Conditioning
- fudge factor for temp sensor (shifts from -2 to +2C)
* automatically turn on recirc mode when A/C turned on (annoying!!!)
Door locks
- lots of auto locking stuff
Keyless Entry
* can the ignition key be anywhere in the car (default) or does it have to be in the front?
I could have sworn there was something somewhere to disable the stupid buzzer when the driver's door is open but I don't seem to have saved that page and I don't feel like paying again quite yet... perhaps once I get my Techstream programmer!
Originally posted by peter_mcc View Post* automatically turn on recirc mode when A/C turned on (annoying!!!)
Otherwise leaving it on just makes the air in the cabin stale and slightly noxious, especially in traffic as it will slowly accumulate CO1 as apposed to passing it through.
I hope you not one of these people that either:
A) have the A/C on vent only and end up with condensation on the outside of the front windshield ( I still laugh the amount of times I see people doing this, although its entertaining to see the variety of patterns modern HVAC systems leave on the windshield these days)
B) Turn the a/c off when you use the heater, I can not believe how so many people think a/c is for cooling only. Its there to dry the air, cooling is a buy product but not a necessary one, hot dry air keeps the windows clear in the wet and it much more comfortable that hot humid air )mobile green house anyone?)[CENTER][B]-=2014 GXL D4D Auto Graphite, Firestone Airbags, ARB/Optima D34 Dual Battery, ARB UVP, TJM Airtech Snorkel[/B][B]=-[/B]
[/CENTER]
These need to be done with techstream or other compatible scan tool. This is done by accessing the BCM via the OBD2 plug.[LEFT]Silver 150 Facelift
Hi Peter.
I like many others hate the entirely pointless open door alarm.
I wrote to Toyota and told them what a bloody annoying piece of crap the alarm is.
I know the door is open, I opened it duhh.
Anyway to answer your question, Toyota can disable the alarm but at the loss of 'auto off' function of your headlights when you open your door.
It was one of the first things I wanted done.
As I am in the South West of WA I always drive with my lights on so that others might take notice that I'm on the road and I would prefer that you took steps to avoid me.
However, I was told that I would loose the auto off function so put up with the door alarm rather than experience a flat battery.
Incidentally, PP has a post that shows you pictorially how to disable the alarm yourself by pulling the dash panel out and on the back there is a small speaker and while the door is open and the alarm is going off, gently insert a short screw into the middle of it until it ceases to annoy. Silence is Golden.
Hope this helps mate.
Graeme
Originally posted by Freddy2370 View PostThanks AussieAndy I do have a obd2 wifi dongle witch I run a program on my laptop so do you think this will work or do I need the tech stream scan tool[LEFT]Silver 150 Facelift
