Can anyone tell what the dick cepik fun country's are like and are they 50% on road and 50% off road ?
Tyre review - Dick Cepek F-C II
http://www.pradopoint.com/showthread...-Radial-F-C-II
Yep great tyres. Love them. Excellent in the mud and rocky terrain. I don't think they are marketed as 50/50 without checking out the brochure. Tough side walls , didn't seem to bag out as much as MT/s at same pressure on last trip but mine were newer. As for wear mine have only done 5000km but JKspinner has had his on a while longer than me
Cheers Matt2008 120 GX D4D with a few extras
Rig build here
They are fine on the road & also in the wet as long as you drive to conditions . Let them down nice & low in the sand & they'll be fine . Be interested to hear how much you paid.
Rig build here
Hi Altitude, I have had them for somewhere between 5000 to 10000kms and cannot fault them. Have mainly used for on road and lots of towing. Have used for OFFROAD for one week and they were brilliant, nothing serious, but lots of slippery grass, sloshy tracks, rocky tracks and creek crossings. They look cool to. I rate them
I hope they treat you well.
I had a set on my old triton took me Birdsville and to Cape York and back
I found them to be a great set of tyres off road there was little difference between mine and a mate with Baja Claws in the mud, good on other surfaces and found in sand I would drop a few extra psi out when airing down,
On road found them be great in both and dry and wet conditions, unfortunately I found from about 35 000klms the wet weather performance begun to fade with a bit over 40k on them they were like a set off muddies in the wet! keep in mind this was bout 7 year ago when they first came to the aussie market and I would like to know if that has changed because until the high kilometres they were a fantastic tyre.
At 40k there was still plenty off tread left on them I upgraded the car you should get at least 60k from them.
I think from memory I ran about 32psi on road unloaded ( dual cab) loaded 38psi in rear 36 front, If your slipping in the wet try knocking a couple of psi out off them I had mine down to 12psi on sand one time I didn't relise until airing up!
