In the process of picking up my Jayco Expanda Outback (1800kg) and keen to see what airbag suspension members have used on their 150. I have a 2" lift.
Prado 150 Airbag Suspension
They assist the rear coil springs to hold the maximum load (up to 450kg in the 150) close to normal unloaded height.
But when unloaded you let the air out to 6psi and the rear end is nice and soft and at normal height.
With these bags you pump them up before applying the load. The max pressure is 30psi.
You can fit them to a vehicle with or without lift.
I have them in the 150 and its great as I have the advantage of a normal vehicle around town and then something that will take some weight on the occassional times I go bush.
They are not as good as the high pressure bellows but you cant fit these to the 150 due to the coil springs. But they are cheaper.
I understand you can get sleeves for the firestone brand but not the polyairs.
I just went for the low pressure polyairs without sleeves as there are few horror stories with overloading and the use of low pressure air bags used at higher pressures.Last edited by Cuvier100; 02-07-2015, 10:04 PM.
I must have firestone then, as they were the two options at ARB. I went with low pressure too, since I wasn't loading anymore than people and a camper trailer. Its worth just to hold the weight of 150L of diesel in my opinion.[CENTER][B]-=2014 GXL D4D Auto Graphite, Firestone Airbags, ARB/Optima D34 Dual Battery, ARB UVP, TJM Airtech Snorkel[/B][B]=-[/B]
[/CENTER]
