VX Broken Headlight
  • VX Broken Headlight
    Just got a shock of the replacement cost of a new front headlight for my VX.
    My 2010 VX Prado has a broken headlight after a bird smashed it.
    I got a quote from the Toyota dealership which was $1000 and has to come direct from Japan as there is none in stock in Australia.
    As the VX has the washer (which i think mine is disables because of the ARB bull bar), will an after market headlight fit or do I have to go for the expensive one form Toyota???
    Anyone know of an aftermarket headlight that would fit and work in my VX???? And details on suppliers would be appreciated. I am in WA.
    Part No.8114560E60 - $780 (plus postage) from Amayama for genuine.
      Try wreckers first. You can buy aftermarket pair under $600. Why your washer is disabled mine's not with Arb bar. Washer doesn't have to do anything with headlight. Is your headlight self leveling low beam. Just double check when you buy new one.
      Pearl white kakadu rolling on fuel hostage 18" with 285 60 18
        I doubt your washer would be disabled, and most likely not from an ARB store. I'm pretty sure it'd make it illegal. Notice how every xenon headlight has the washer... it's a requirement under the ADRs. ARB's surely not going to disable that.... surely???
          If you are going to go the aftermarket way than be careful. The Prado's Computer might reject the aftermarket headlight and throw error codes and the aftermarket headlight might not work.
