I had to remove the spare and cradle on the GXL last week so that the window tint could be done. (They cut the tint on the outside because the window is convex)
There is an issue with overtightning of the bolt that holds the cover on and also the locking nut on the spare.
You wont undo the 12mm bolt that holds the cover on with an open end spanner, it will need a socket and bar.
And now the good part, the locking nut is a very soft alloy nut and when you go to undo it, it squashes and then sheers off leaving a round alloy ring on the stud threads.
So you cant get the spare off.
I took it to the dealer who fixed the problem there and then. He rolled his eyes and told me it is an issue and if these are not backed off by the dealer when the PD is done you will have problems.
Better to find out now than on the side of the road!!
