I want to install a single DIN CB Radio in the Prado. I would like to put it in the space below the Aircon control. Is there an aftermarket insert to replace the pocket with the door over it. Double DIN would be OK as I will just put a single pocket in there..
2014 Prado Lower Dash Pocket Mount Radio
Sorry I can’t answer your question directly, but have you looked into the gme xrs range.
I have the xrs 370, it mounts up under the dash some where with a pass through comms port installed in the dash. All the controls are in the handset, so you have a clean dash and no extra bits hanging around. Unplugs easily for around town too.
