G'day, I have a kdj150. 2014 196,000 Severe vibration/bounce coming through brake pedal and car physically jerking whilst slowing down, consistent with brake pedal. Thought my rotors were warped so replaced along with new pads as you do. Problem still evident. When I "punch " the brake pedal down hard. Normal braking conditions return for a few minutes. Then back to the pulsating again. Im Thinking the calliper pistons may be the culprit and there not pressing out to the rotor correctly/on an angle. Has anyone else experienced this. I'm quite capable on the tools , are they easy enough to overhaul callipers at home? Cheers
Braking issues kdj150
