What is this Towbar module in Prado 150
  • What is this Towbar module in Prado 150
    Can someone tell me what the white module just behind the left rear taillight is for.. I know the towbar electricals plug in but it has some sort of circuit board inside it?
    I'm thinking of running the earth pin from the towbar plug back to the battery as I'm having issues with my brake controller not locking the camper trailer wheels & I'm all out of ideas..
    Don
    2010 Prado GXL D4D Auto , BFG A/T , DVD Console , Tekonsha P3 , Projecta Dual battery system , Piranha dual battery tray..
    Jayco outback expanda
    Re: What is this Towbar module in Prado 150
    Any chance of a picture so we know exactly what you mean?
    Mike
      Hi,
      If you mean the 'controller' that the cables plug into behind the rear left panel, then you should be aware that these modern vehicles use various electronic control systems for distribution of power and signals. In the 150 it is known as 'Canbus' and is implemented in a big way. This is why you should not try to take the brake switch line from the pedal to an electronic brake contoller (because it's not a 12v line), and instead tap into the stop light circuit at the rear of the vehicle. See my post here viewtopic.php?f=47&t=8040#p112598 . I think the controller you refer to takes electronic control signals for items such rear stop lights, tail lights, etc. (possibly other items such as parking radars, camera as well), and provides the power at the right voltage to drive them.
      Without access to actual circuitry it is difficult to know exactly what it is doing.
      Rgds, Rob
        Thanks for the info.
        Yes that is the module I was referring to just behind the left tail light. I won't touch it if it's tied in with all the other electrics. Was going to run a thicker ground wire from the trailer socket back to the battery for the earth pin.
          It also does a few groovy things like deactivating the reverse sensors when a trailer is pluged in. I'd exercise extreme care if playing around!
            Does this only work with the genuine Toyo tow bar? as I have an aftermarket towbar fitted and Toyo said this is not possible with any rear towbar???
            Prado 150 Kakadu, D4D 5-Spd Auto, Silver, Full Window Tint, Hayman-Reese Towbar, Rhino-Bars, GME TX3400 radio, ARB Deluxe Combination Bar, Hella 2000 Driving Lights. PE Brake controller and Complete Campsite XT Camper Trailer
