Modifying 150 Prado GXL manual for touring
  • Modifying 150 Prado GXL manual for touring
    Hi
    I am new to this forum having only picked up our new Prado last week. I want to pull the second row seats out (have already pulled the third row seats out) I also want to run a wire from my second battery (already installed) to the Engel that will be accessed through the passenger side rear door. A couple of questions that members may have answers for are:- How do you remove the plastic sill under the driver's door? Has anyone taken out the fuel card/credit card holder in the glove box? (would like to put the brake controller there) and has anyone taken the second row seats out? If so how.
    I don't know how to drive this forum yet, hope this post finds its way into the system. Thanks to anyone who can help.
    Cheers PeterD
    Re: Modifying 150 Prado GXL manual for touring
    Originally posted by PeterD
    Hi
    Cheers PeterD
    Peter, welcome to the forum, if you use the search buttom you will pick up your answers, i asked for "credit card holder" and got the topic below about removal,
    viewtopic.php?f=45&t=10993
    their is a lots of info here, have a good read first and or do some searching otherwise we end up with multiple threads of the same thing.
    [b]Rob[/b]
      Hi
      Hi Peter,
      Check out my build up thread, the link is in my signature below. You will see under the section where I installed my UHF I removed the trims I think you are talking about. Not much to it, just a firm pull and they should come out, they have those plastic lugs on the back. If you break any getting the trim off, Supercheap has spares
      [b]--Dave[/b]
      [color=#4000BF]150 GXL D4D Auto, Ironman Suspension - 2" lift Foam Cell, GME TX3340 UHF, RustStop RS-4 electronic rust protection, Hayman Reese towbar, BFG AT's 265/65/17, Rhino Racks, ARB Awning, Sandgrabber Mats[/color]
      [url=http://www.pradopoint.com/viewtopic.php?f=38&t=8368][i]My Build Up[/i][/url]
        Hi
        Hi Peter,
        Thanks davidsford. had a look at the photo of the sill removed and will have a bit more confidence to give it a reef now without fear of busting something expensive.
        Regards
        PeterD
