I have the Gibson Tru Body bracket and the top of the spring is equal to or just under the standard height of the roof rails. This photo was taken in 2009 from the rear and slightly lower which makes the antenna spring look a little higher but it is not in reality.
![](http://vk4tx.no-ip.com/photos/install/Antenna%20Bracket.jpg)
I picked up my new 150 about a month ago and fitted ferrite beads to the injector leads. I also fitted a braid across the read door hinge, dropped this down to the pick up the body then a hose clamp onto the exhaust clamp. I ran a 25mm cable from the aux battery (through a breaker) and kept all the codan cables under my storage system with a fuse box where I then fed power to my other radios and fridge. I found this significantly reduced the injector noise. Will take some photos and post these next week when I am off night work.
Nifty
Nifty
