LED indicator/parker assembly for TJM T13 bullbar
  • LED indicator/parker assembly for TJM T13 bullbar
    Has anyone done a retrofit install of the TJM LED indicator and parker assembly for the T13 bullbar? Is it tricky or fairly straightforward? Is it worth it?
    I have searched but can only find references to ARB bars or where people have purchased the TJM bar but had the LED indicators fitted pre-delivery.
    ping Rogerthatv2 he installed some on his I believe
      OK, shall do.
        Easy fit Corine, I bought mine from TJM Brendale, they are LED Technologies brand from memory. Looks great and took about 5 minutes a side to fit.
        Daniel
          Thanks Daniel. Is it easy enough to remove the old lamps once you drop the wing plates under the bar?
            Did not need to drop the wing plates, easily unscrew from the front of the indicators once you pull them off. There is plenty of room in the indicator hole to join the wires etc.
            Rogerthatv2
            Daniel
              Awesome, will be swapping out the old indicators soon. They work but I notice they keep getting water inside and they aren't that bright.
                The LEDs are great, looks heaps better.
                Daniel
                  I've installed them on my bar, they are much better, easy to do, worth the effort to change the indicators over IMO!
                  Silver 2012 150 series D4D Altitude Prado, TJM T13 Bar, Airtec Snorkel, Koni HT Raids suspension, TG150 Transfer case guard, Dual Battery, LightForce Genesis 210 35w HID, Rhino Rack Pioneer Platform, Foxwing awning, MaxTrax, TraxRax, Cooper's AT3, GME TX 3540, Sand Grabber mats, Hema HN6, Drifta Draws, ABR - Sidewinder Kit, MSA Fridge Drop Slide, Engel 40L, Brown David underbody plates.
