Just had new suspension fitted
  • Just had new suspension fitted
    Just had 50mm lift fitted by ultimate suspension after putting about 200kgs over the front like arb bar ,winch,dual batteries etc. It dropped 2inches the guys at ultimate suspension lifted 65mm from standard height they said this would sag to a true 50mm lift what a difference cant wait to take off road
    2010 PRADO D4D/ARB STEEL BAR/9000LBS WINCH/DUAL BATTERIES/ICOM UHF/50MM LIFT/NARVA SPOTTIES/TJM SNORKEL/TJM UNDERBODY PROTECTION
    any pics??
    what springs did they fit for you? comfort or heavy duty?
    sam (hookedon4wding) is getting his ultimate suspension kit fitted next week. he's getting the comfort springs from memory.
    louie
    Silver 150 GXL V6 Auto: TJM T13 bull bar, Avenger Mako TDS 9.5 winch, 2" lift - Bilstein shocks King springs, factory tow bar, Piranha battery tray, Red Arc isolator, E-Nex DC24MF battery, GME TX3540 UHF, ARB 47L fridge, ARB fridge slide, IPF spotties, Tekonsha P3 brake controller
      Sounds good, hows the ride on road ?
      [size=1]2011 GXL D4D Auto | ARB Deluxe winch bar | Bilstein/Ridepro platinum lift | MT ATZ P3's | Dick Cepek Torque rims | Airtec snorkel | Lightforce Genesis 55w HID | GME UHF | 55w HID high beam | Rhino Rack bars & Cage | ISI extreme rack | Dual Optima Batteries | Milford MXV-70 cargo barrier | ARB onboard air | Prodigy P3 | Drawers & Black widow fridge slide | Waeco CF-50 | Kaymar rear bracket and LED light | EscapeGear seat covers | Sandgrabbas and more...[/size]
        They fitted comfort in the front and heavy on the rear as i tow a van the ride is much better than standard pics are on the way
          Mine goes in on Thursday. I received all the components today (express freight overnight).
          I have Coil-Rite airbags in the rear, hence Brendan recommended comfort (medium) coils in the back as well. This way it shouldn't be to hard around town but can be supported by the bags when the trailer is hooked up.
          Scutto, do you know what height setting they used for the front spring seat. As the struts have an adjustable spring seat, this can be adjusted to match the weight. Brendan has told me to fit my struts in the standard raised position until I get my bar and then raise the spring seat if need be when the steel bar goes on. Sounds like you've got the same setup. I presume the 65mm lift on the front is on one of the raised spring seat positions?
          Can't wait for mine.
          Photos would be great.
          Cheers, Sam.
            Had my Ultimate 2" Lift installed today. Very happy! See my rig build up for a couple of photos. http://www.pradopoint.com/showthread...s-150-V6/page2
              they installed 2x 20mm spacers and 1x 10mm into each strut
                This thread is boring without PICS!!!
                [B][SIZE=4]ntp
                  Gday to all
                  Finally get to pick up my new GXL diesel next week, after a 6 month wait,can hardly wait.
                  The BFG MTs and TJM barwork are ready to go, but now for the suspension.
                  I am thinking of Lovell springs and Bilstein shocks, What are your thoughts.
                  Should I go heavy duty or comfort all round, or one on the front and other on rear.
                  Or is there better options that I shoud look at, love to hear what others are doing.
                  Regards
                  Top Truck
                  2011 White GXL Manual, TJM T13 Bar, X-Ray Vision HID 220 Driving lights, 265/70/17 Mickey Thompson S T Z tyres, Airtec Snorkel, Uniden 7700NB UHF, Ruffnuts Seatcover, TJM XGS Gold Suspension, Drifter Draws, Sidewinder Dual Battery System.
                    Originally posted by top truck View Post
                    Gday to all
                    Regards
                    Top Truck
                    As I posted in another thread, I have TJM suspension: heavy duty springs and shocks in the front to take the weight of the TJM steel bar and 2nd battery, and medium weight springs and coils, and Poly Air bags in the rear to take the weight of the drawer system. The rear sits up higher than the front, however, when I add my van, the rear drops to the same height as the front and the van sits level as well.
                    I would not use comfort level on the front if you are adding a steel bar, the weight will be too heavy for that set-up and will affect the steering and tyre wear.
                    Yowie.
