lift options for 150 wagon - how to go higher than 50mm?
  • lift options for 150 wagon - how to go higher than 50mm?
    G'day,
    I have a 150 series GX 2012 wagon. It has a 50mm lift but this does not cut it for serious 4WD work - I am wondering if there is anybody with experience out there with lifting further using things like strut spacers and body lifts such as those advertised by Superior Engineering (https://www.superiorengineering.com....ft-alloy-19819).
    If I do lift it further do I need to get 17" wheels and tyres etc = $$$$$$
    Any ideas or comments would most appreciated,
    thanks Joe
    Hey Joe,
    As soon as you lift over 40-50mm on the Prado IFS you lose droop in a 1:1 ratio, so lift 10mm, lose 10mm droop etc. This happens even on the longest struts possible, and is an inescapable function of the IFS geometry, see here;
    http://www.pradopoint.com.au/showthr...-Prado-120-IFS
    On a long 570mm strut at 3" lift, you'll have around 60mm of droop, not so good anymore for that serious 4wd work, and you will top the struts out repetitively.
    Strut spacers are bad news, see here;
    http://www.pradopoint.com.au/showthr...can-they-break
    You can however do a 2" body lift with a 2" suspension lift, which might cut the mustard for you.
    Give John at Zordos Suspension a call, he's up on the north side of Brisbane, and he does suspension and body lifts on everything!
    Best
    Mark
