will a 265/70/r17 fit into the spare wheel holder on a gxl
will a 265/70/r17 fit on the spare wheel mount?
Depends I think, I've just fitted the cooper st Maxx and it almost fits however the extra lugs on the sidewalks of the ST Maxx is preventing it going on properly, more width than overal height preventing it I believe. There is foam pieces inside the cover I cut them write back thinking that it would fit but to no avail. Ended up putting a few washers on the studs and mounting without the back and front cover.[SIZE=1][B][COLOR=#ff0000]2010 Silver GXL Prado T/D Auto.
[/COLOR][COLOR=#0000ff]2014 Leisure Matters X-Track Camper Trailer.[/COLOR][/B][/SIZE]
I have ST MAXX 265/70/17 on the 150 and it fits fine, the ST looks like it has more tread which may interfere with the rear step (bigger circumference), I think you should be OK but it will be close, see if the tyre joint can try it on for you.
What price are you getting? I hear they are more expensive than the ST MAXX?
Fabs, are you talking about putting the cover back on is restricted?
Bernie
Originally posted by berniebgf View PostI have ST MAXX 265/70/17 on the 150 and it fits fine, the ST looks like it has more tread which may interfere with the rear step (bigger circumference), I think you should be OK but it will be close, see if the tyre joint can try it on for you.
Bernie
I couldn't get the spare wheel cover to fit properly.
Have you been able to get your cover on?[SIZE=1][B][COLOR=#ff0000]2010 Silver GXL Prado T/D Auto.
Question - Will I get any rubbing if I fit ST MAXX 265/70/17 to my standard ride height 120?
Edit - Oops, sorry, just realised I'm in the 150 forum.....Last edited by ToeEdge; 14-01-2013, 02:05 AM.[b][color=#800040]2007 120 GXL D4D 6sp Man[/color][/b]
