275/50 285/50 offset for 20" questions
  • 275/50 285/50 offset for 20" questions
    Hey guys posted at general but should have posted here as i might get more specific andwers here. Looking at doing 20inch rims for my 150 and 275/50 or 285/50 tires are what i gather to be closest to stock diameter, just wanted to check what offset i should be getting so it won't rub during full turns.
    Not planning to lift anytime soon but is it better if i do ? 2" ?
    +20 should be okay ?
    275/50R20 with +20 offset should theoretically be ok.
      275 50 20 +20 might just clear the inner guards and sway bar but will run very close to the standard upper control arms.
      Where are you located Pradoristi? If in Brisbane I can help.
      ZR
      [url]http://www.pradopoint.com/showthread.php?28607-GUV-s-ZR[/url]
        Thanks for the reply guys , not located in AUS unfortunately
        what would be a good and safe offset ?
        Pradoristi
        Lurker
          Try using this site as a guide.
          http://www.willtheyfit.com/index.php...et2=20#content
          ZR
