Request to check wheel alignment numbers
Originally posted by RB80 View PostHi, just had an alignment post-DIY suspension w/2in lift.
I'd appreciate if someone can spot if any of the numbers pre or post look out of place. Thanks in advance,
[ATTACH=CONFIG]24604[/ATTACH]
Not the greatest alignment figures I've seen.
Prado front end always drives better in my opinion with a little toe in and negative camber (1.0mm toe in and -0.25deg both sides), removes a bit of the twitchy high speed feeling and gives better cornering.
Caster you have is low as you're likely still running OEM arms, and is better to have minimum of 2.5deg.
Best
Best
Mark
Originally posted by 120D4D View PostHow did they adjust the Toe and Camber on the rear axle?
