Steel Rims for 150 GX
  • Steel Rims for 150 GX
    Just took delivery of a new 150 GX. Want to get another spare tyre just on a steel rim. Went to Bob Jane today and they had had trouble tracking one down. Does anybody know where I might be able to get one Perth.
    Re: Steel Rims for 150 GX
    Toyota sell 17 inch steel rims for about $150. They made them for a special edition Prado.
    Hope this helps
    Andre
      Hope this helps
      Andre
      Are you referring to the Pilbara rims for the 120 series? Note that the wheel offset for the 120 is different to the 150 by 5mm. So just be aware that you can't swap 120 and 150 wheels.
      I believe that the 3rd party manufacturers now have suitable wheels for the 150. There was a thread about it but I can't find the exact one. Here are a few I did find.
      viewtopic.php?f=55&t=8864&hilit=+wheel#p119217
      viewtopic.php?f=55&t=9755&hilit=+wheel
        Hope this helps
        Andre
        Hi Guys
        Yes you can run 120 steel rims on a 150 series as I currently have a set on my 150.
        Peter
        [color=#4000FF]2010 GXL, ARB BAR, GOODYEAR MTR'S ON STEEL RIMS, CUSTOM REAR DRAWERS, DUAL BATTERIES, CARGO BARRIER, GME UHF, RHINO ROOF RACK, ROCK SLIDERS, AIRTEC SNORKEL, DUAL DROP FRIDGE SLIDES[/color]
          You can run 120 rims on a 150 but it was not designed to because it will make the wheel track smaller and you may increase the risk of instability. If anything happens and the rims are the cause, expect your insurer to reject the claim as the 120 rims has altered the spec of the 150's wheel track.
            Had my Local Dealer do a search for me and they could not find any steel rims for a 150. I asked about fitting rims designed for the 120 and they just advised that due to the possible insurance issues, they would not fit them.
            150 GXL Glacier White D4D Auto,Headlight/Bonnet Protectors, Weathershields, Black widow Drawer / Fridge Slide, ARB Fridge, Satin Black ARB Delux Bull bar, Hema 5" GPS, ARB Dual battery System, Genuine Toyota Towbar, Tinted windows, Sandgrabber Mats, IPF 900 Xtreme Spotties, GME 3440 UHF Radio, Safari Snorkel, Toyota TPMS,
              I have a 150 GX with the standard rims and tyres AT 20 Grandtrek
              I used these on my 10500 trek to Cape York in May june
              Went ok but did not do the Hard trek
              Neeed to now ger something with better traction so have always had BFG on a 100 series and 80 series.
              Normally get 100-140KMS from them!
              In all the forums it seems Steel Rims are unobtainable.
              Some say use steel rims from 120 series but others say NO, they will void the Insurance?
              Some say use a Speedie Wheel, alloy I think but want Steel for the bush especially if have to use Tyre Pliers.
              So is there anyone out there who has done a switch to something else?
              Can I use the GXL Rims with BFG All terrains but do they come in steel?
              I do know I can fit Cooper tyres annd Pirelli AT to these rims but do like the BFG all terrains for side wall integrity.
              Regards
              Leighland
                are the wheels nuts the same between steel rims and alloy ones?
                  Yes and no, depending on which steel and alloy wheel you are comparing.
                  Generally, the Toyota alloys are the flanged type and steel wheels use a tapered nut. However, the Speedy Grande wheels initially came out with the flanged type but then switched to tapered nuts.
                    The wheel nuts are different for steel and alloy rims. Alloy rims will use a step which sits inside the wheel stud opening of the rim. Steel rims use a taper to centre the stud in the opening. The reason for this is alloy isn't a strong metal and the taper on steel rim nuts could crack the alloy rim.
                    120 steel rims fit on fine and used them on several trips away.
                    As for insurance, for a claim to be rejected it has to be proven that the particular modification played a part in causing the accident. By loading the rear of your car with heavy things at the top, there for increasing your centre of gravity, would be more dangerous than 5mm less off set. By actually putting LT tyres on these rims the tread of the tyre is actually the same as the Grandtrek with its softer sidewall (which bags out more) on the standard rim.
                    Peter
                      To undertrack a vehicle from manufacturer's spec is illegal/unroadworthy and therefore voids your insurance. Be prepared to put up a fight with the insurance company should they find out that the vehicle was unroadworthy.
                      I'm not sure what you are trying to say. It is Friday afternoon after all and my brain has gone AWOL
                        Hey guys, I started this thread way back in June and still have not got any joy from looking everywhere. I am an amateur in this but I think that one of the issues is the wheel size on the Prado 150GX - 17 inch by 6.5 inch. The 150 GXL is - 17 inch x 7.5 inch. The one 120 series was 17 inch x 7.5 inch. I assume wheel width has a big thing to do with it ?
                          The factors that influence whether a wheel is suitable is:
                          - Diameter
                          - Width
                          - Offset
                          - Backspacing
                          The major differnce between the 120 & 150 wheel is the offset. Give the wheel manufacturers some time and they will come up with a suitable one for the 150. Or keep an eye on ebay. I have already seen a set of 4 there.
                          The 245/70R17 is not too bad. At least there are decent 4WD tyres in that size.
                            I am about to put 120 steel wheel 17 x 7.5 rims with Bridgestone D694Lt rubber on my 150 GX. Not particularly worried about the 5mm offset difference but can you add a 5mm spacer to fix the issue? This might be a stupid question as I am not a wheel expert.
                            Mike
                            Mike
                              Wheel spacers are illegal.
